Hesitation???
Old Aug 30, 2003 | 09:54 AM
DOHCammin's Avatar
Car Info: 05 CGM FXT STi
I occasionally get that in second gear at WOT, but mine is a US spec 03 rex. I've had 2 check engine lights that came on for 1 day each (misfire cylinder 1) but other than that, I cant figure out why it does it. it feels almost as if it was a bad shift but the clutch isn't engaged.
Old Aug 30, 2003 | 09:44 PM
IANOC, what plugs are you running? Try switching to NGK coppers if you aren't already, and make sure they are the correct heat range. Also, try doing the grounding mod. That has cured hesitation for a lot of people in the past. The new exhaust shouldn't be the culprit in any case.
Old Sep 7, 2003 | 12:42 PM
KINGSKY's Avatar
Car Info: GC8 ej20 motor, 18" gramlights on yokos,
i have a 02 wrx usdm motor. before, i had a MISFIRE code on 1/3 but for some reason it went away (hope it stays away). at 2500 rpm she hesitates, used various ECUs, tried different kinds of spark plug and nothing. ohhh, i do have CEL. i am stock.
i've read from doing search that it could be the COILPACK or the EGT on the up-pipe. it was also suggested that to take it to get a COMPRESSION check at the dealer. i'll try to take it to the dealer and get it checked for compression 1st.
KINGSKY
NeVzWRX
Jun 23, 2003 11:38 AM
jwzekas
Mar 9, 2003 04:31 PM
jimr
Feb 18, 2003 08:54 PM
Mandra
Jan 2, 2003 05:55 PM
wrxtacy
Dec 12, 2002 12:40 AM
