Helix Catted Downpipe GOOD INFO !
Old Nov 2, 2005 | 10:41 AM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Originally Posted by WRX Rush
High flow catted midpipes are like **** on a nun, they do nothing, if you still have that far too restrictive primary cat, or downpipe then the midpipe makes no difference.
Austin
I currently am running a stromung dp with the stock third cat, until I save up for the high flow third pipe cat.
So you're saying a highflow third cat would do nothing for me and I should just get the third cat delete pipe?
Old Nov 2, 2005 | 05:16 PM
Boost Addict's Avatar
I think you will definitely clean things up if you get a high flow catted mid pipe... why not? and horsepower-wise it wont make much difference in peak numbers... There just isnt that much restriction... and your car will not smell as bad...
Old Nov 4, 2005 | 12:35 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
916 Dave: The catyletic convertor on the midpipe will not be as efficent as one in the downpipe because it is further away from the heatsource. But I originally thought that you were just putting a high flow cat on the midpipe with the stock 2nd cat, my mistake. The Catted-midpipe section would work very well for you.
VIBEELEVEN: If you have a stock midpipe and are going to go for the larger diameter with high flow cat, that would be the best route. I was also mistaken when you said you were going to use that, like I previously said they are a little farther from the heat source so they take a little longer to heat but besides that, the setup will do well for you !
Cheers !
Austin
Old Dec 17, 2005 | 01:21 PM
AJBoost's Avatar
Car Info: C32 AMG, Lincoln Navigator, LS1 Trans Am, E36 Bmw
Smile Sound?
I have a question about the catted vs. non in regards to sound. That is, does the catted produce a "quieter" sound note than a non-catted version? I'm currently running an apex-i N1 on my 05 WRX, looking to upgrade the DP as I understand a ton of added power can be had there. Just not looking to blow my ear drums out. Already did that enough with my open header'd fox body! =P Thanx!
Old Dec 17, 2005 | 04:58 PM
WRX Rush's Avatar
AJ-
If you think you can handle the 'next step' on your 05 WRX, and you already have an up-pipe, get a catted downpipe, that should be at your barrier for sound for the N1, since it is a loud exhaust. Then if you decide you want to go louder, get headers, and then go for the catless downpipe.
Austin
Old Dec 19, 2005 | 02:34 PM
humara's Avatar
all other things being equal, you will not hear much of a difference between a helix catted or uncatted downpipe when bolted to your n1.
Old Dec 19, 2005 | 05:28 PM
bagwellfive's Avatar
Car Info: 2004 WRX
this is great info..
i just had a catted helix / uppipe / borla hush installed and I was curious about this.
thanks bud
Old Dec 20, 2005 | 10:51 AM
2bluewagons's Avatar
Car Info: 2004 wrx wagon
I am at some point looking to install UP + TBE, maybe catted, maybe non. Either way, I have access to emissions testing equipment (not the same as DMV, actually much more sophisticated) and I plan on getting pre and post numbers. I'll update when I get the cash to buy the pipes, but as of now house payments take priority.
bballchris24
Jan 23, 2010 05:12 PM
bballchris24
Jan 23, 2010 05:11 PM
SG5
Oct 7, 2006 11:19 PM
nathanellis
Jan 14, 2005 04:08 PM
