Heads
Old Oct 22, 2003 | 04:07 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Yes you can.
They will work.
You can run them WITH or WITHOUT hooking up the AVCS.
If you choose not to hook it up, your car will loose bottom end but gain gobs of top end.
If you choose to hook it up, you will need a JDM ECU and add some wires (Left and right AVCS cam sensors, L/R AVCS selenoids).
There are few diff AVCS heads available in Japan.
1. STi AVCS
2. STi Spec C AVCS
3. Non-STi AVCS
All of the above are far better heads than the US ones. AVCS/cams and valves aside. The casting is slightly different. The ports are a lot larger and designed better for improved flow. Also, both utilize "shim under bucket" for improved valvetrain performance. If you plan to high rev your EJ20, thats a must.
Then, there is a diff between the STi and Non-STi heads. The valve material. STi has hollow intake valves and sodium filled exhast valves which the non-STi does not. Also, the exhaust valves on STi heads are ~ .5mm larger.
Then all 3 have different cams. The most agressive are the Spec C cams. They are "spicy" but provide great idle even with AVCS disabled.
For myself, I got non-STi AVCS heads. Stuffed it with Spec C cams and buckets and custom dual rate springs and Ti retainers. Overall, the best bang for the buck if you want a crazy head. My car revs to 9500 like a champ. Sounds like an airplane when it hits 8300RPM.
Old Oct 23, 2003 | 12:44 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
Imprezer, thanks for posting all the info, I have been looking for the same specs. Your motor sounds absolutely wicked. Do you happen to have the valve timing for the Spec C cams? Thanks again for the awesome info.
Old Oct 29, 2003 | 05:13 PM
Slamsitin's Avatar
Car Info: 03 yellow WRX stage 1
Who says that a higher rev limit is goin to make u go faster? Powerpeaks then starts to drop off.
Old Oct 29, 2003 | 09:56 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
QUICK ALEX.. MAKE A WAV I WANNA HEAR IT !!!
Old Oct 31, 2003 | 10:34 PM
Imprezer's Avatar
Admin v2.0
T67 :banana:
Old Nov 1, 2003 | 05:37 PM
push2's Avatar
Car Info: 02 GGA
not to jack the thread but whats the diff between a type c and the s202 motors, ie heads mostly? thanks
WorldONE
Engine and Drivetrain
Apr 13, 2007 06:22 PM
EJ20Legacy
Nov 13, 2006 05:47 PM
gruppe-s
Jul 21, 2005 08:32 AM
areg
Wanted
Nov 24, 2002 07:20 PM
scottm1978
Wanted
Nov 22, 2002 07:47 PM
