hallman evolution MBC?
Old Mar 25, 2003 | 07:45 AM
ride5000's Avatar
from the boostcontroler.com website:
The new Hallman EVOLUTION Kit and Hallman EVOLUTION RX Kit both use the same valves as the Pro and Pro RX Kits (see above), and have the same features, but ALSO are integrated into a self-contained cockpit controller cable system.
Both of these kits also contain a mounting bracket, 3 feet of hose, a hardware kit, and specific installation instructions. The cable is 72 inches in length. Available in Red or Black.
The self contained cable system allows you to adjust boost from inside your car! This new system makes it very easy to set initial desired boost level... there is no need to stop the car, pop the hood, adjust the valve, then drive to see what boost level it is set at (and possibly repeating this process several times). Sitting at a red light and want to turn up the boost? Its just an arm's reach away.
This unique cable system uses a sheathed cable that does not twist or bind. There is no "lateral torque". This means that you achieve consistent results when you turn your inside-the-cockpit adjustment ****. Just as precise as if you were turning a **** on the controller itself, as with the Hallman Pro or Hallman Pro RX kits.
this seems REALLY cool to me... like the convenience of an EBC with the solid reliability of an MBC. if you have an PTFB situation, you just dial down the boost. driving like grandma? dial down the boost. boogie-ing down some back roads? dial UP the boost! weather affecting the boost level? tweak it from the cockpit, WHILE DRIVING.
cons: kinda pricey at like $160. otoh, hallman makes very nice BCs and i'm sure this one will last forever.
anybody see one of these installed somewhere? maybe even have one installed on their own car? please share!!!
tia,
ken
evo8dustu
Jul 25, 2006 12:57 PM
Renegade
Dec 14, 2005 07:56 PM
Yepwrx
Oct 10, 2005 10:47 AM
gruppe-s
Vendor Group Buys/Specials
Jun 3, 2004 11:44 AM
