gutted stock DP
Old Apr 27, 2006 | 03:53 PM
johsti's Avatar
Car Info: 2004 WRX Wagon PSM
gutted stock DP
I'm currently running a full 3" TBE w/ hiflo cat, and a catless uppipe and cobb stage 2. I want to quiet things down to "stock" quiet at the expense of losing some power. I was thinking about using a stock gutted DP with stock 3rd cat, resonator, and muffler. Maybe I'll add an sti axleback.
Does anyone have experience with a gutted stock DP with cobb stage 2?
Old Apr 28, 2006 | 05:22 PM
ILiveAgain's Avatar
Car Info: 03 WRX Wagon
what year is your car?
Old Apr 29, 2006 | 03:28 PM
stanh04wrx's Avatar
I've been running a gutted stock dp on a cobb stage 2 car for just under two years now.
No problems at all.
Old May 3, 2006 | 10:53 PM
apexwagon's Avatar
Car Info: Sti hatch
dont waste money on an sti axleback its the same as an 05 wrx axleback but it says "sti" on it.
Old May 8, 2006 | 04:22 PM
johsti's Avatar
I have an 04.
Is that true, an sti muffler is the same as an 05 muffler? I thought the 05 bottlenecked after the flange just like the 02-04 twin tip mufflers. I know the tips look similar.
Old May 8, 2006 | 05:31 PM
laoba's Avatar
Car Info: rx8
i believe they're the same also, but ive read that it may be chambered differently
i have a prodrive oval exhaust. looks very stock, quiet at cruise but makes itself known when you get on it i bought mine used for $250
Old May 9, 2006 | 08:48 AM
johsti's Avatar
I used to have an oval tipped Scorpion. Exactly the same as the Prodrive oval except it had a scorpion on the tip. I agree, it's very quiet for an aftermarket exhaust, but I'm looking for "stock" quiet.
I just bought a used Stromung DW DP instead of the gutted stock DP. I'm thinking the new setup will be sti UP, Stromung DP and stock 3rd/resonator/axleback. I know I'll be leaving some power on the table, but it will be very quiet, and I'll have at least one cat (I won't go catless). Maybe later I'll add a Stromung hi/flo 3rd cat later.
Old May 9, 2006 | 09:54 AM
johsti's Avatar
The pipes are the same size at the flange on the 02-05 wrx muffler and the STI muffler. However, if you look right past the flange, the wrx mufflers taper down about .25". The STI muffler does not taper right after the flange.
Yin
Oct 29, 2008 11:46 AM
VitaminWRX
Sep 8, 2006 09:03 AM
soggynoodles
Mar 27, 2006 04:01 PM
FreeBMW
Feb 3, 2003 01:08 PM
1wrx2goplz
Jan 19, 2003 09:45 PM
