Greddy profec question
Old Dec 29, 2004 | 09:32 AM
VIBEELEVEN's Avatar
Car Info: 03 WRX
So I'm looking through the semi worthless directions, and it tells me I have to splice into the vacum line on the fuel pressure reg. I trace the lines back to the filter, but I can't seem to figure out what they're talking about.
Old Dec 29, 2004 | 03:18 PM
Donkey's Avatar
Car Info: 02' WRX
Just splice into the one that goes to the fuel regulator on the fuel rail.
Old Dec 29, 2004 | 03:20 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
wich side regulater the on? And where is it? I can only find the filter.
Old Dec 29, 2004 | 05:58 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Found it, thanks, The subaru dealership where I live told me it was on the driver side
Old Dec 29, 2004 | 10:03 PM
mmboost's Avatar
For future readers....the FPR is snuggly fit under the coolant reservoir on the passenger side of the intake manifold. Its easier to spot by looking for the nipple coming off the front passenger intake manifold plenum which the FPR reads boost from. MAKE SURE THIS LINE IS RE-CONNECTED and snug on there - if not you could end up running very lean.
jason
Old Dec 30, 2004 | 11:31 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Also, If you need to access this don't get lazy like I did, take off your intake ! Check the o-ring too, mine was ****ed up and started spraying fuel. AAAAAAHHHHHH ! I didn't check the o-ring and tightened the bolt too much, thus stripping it, please learn from my mistake. keyword fuel pressure regulater , fuel rail
GREDDYWRX
Dec 5, 2010 07:08 AM
dgp2003wrx
Apr 30, 2005 07:31 PM
NRTmotorsports
Aug 7, 2003 08:15 AM
dracing77
Dec 4, 2002 03:32 PM
Hassassin
Nov 29, 2002 11:48 AM
