Greddy Evo Exhaust Replacement Gasket
Old Jan 2, 2005 | 12:44 PM
namitherussian's Avatar
Car Info: Black WRX
try calling Greddy
Old Jan 3, 2005 | 03:47 PM
willow's Avatar
Car Info: wrx02
or you could make your own like I did. I bought high temp gasket sheet and cut some gaskets out. It should only cause about 4-7 dollars. No leaks until a few days ago. It got toasted. However I was runing that gasket more than a year. I just replaced it with one of left overs from last time. Still have 10 cut outs left.
Old Jan 3, 2005 | 04:05 PM
MO REX's Avatar
Car Info: 02 PSM WRX
If you'r looking for a 3" (80mm) gasket this place sells them http://www.racingbeat.com/FRmazda3.htm. These gaskets have 7/16-inch diameter mounting holes spaced 4-3/16 a part (from center-to-center), they worked with my Stromung flanges but you might want to measure to make sure they will work with your setup.
Old Jan 31, 2006 | 09:44 AM
rlovrin1's Avatar
Car Info: '99 Honda Civic Si
Just wanted to let people know, if you keep getting the run-around from Greddy about gaskets, goto Kidimports.com. They sell Greddy replacement gaskets in 60,70, & 80mm sizes.
Kidimports.com Greddy Gasket Link
Old Jan 31, 2006 | 09:49 AM
projectwrx's Avatar
Car Info: wrx
cant you just use a regular 3 inch exhaust gasket that gruppe-s sells?
Old Jan 31, 2006 | 10:55 AM
RU-X's Avatar
Car Info: 05 wrx
sorry to hijack... but, if the gaskets are still good can they be reused? the exhast gasket isn't a crush gasket it is?
hYpE-R-29
May 8, 2013 05:52 PM
Heedz
Feb 28, 2013 12:56 AM
hYpE-R-29
Sep 10, 2012 05:12 PM
Irish_car_B0mb
Feb 18, 2011 12:47 AM
bpang1
Nov 8, 2005 10:32 PM
