going into first when car is rolling (5km/h)
Old May 25, 2005 | 05:45 PM
jlam86's Avatar
I noticed my car won't allow me to switch into first when I'm going really slow. It has to be pretty much at a dead stop before it will allow me to. Is this common with all subaru's or what?
Also, my second gear sounds a little funny. Doesn't do it all the time. Just when it feels like it. It makes more of a high pitched noise. Hard to explain. Definately not quite like the rest. Assistance please!
thanks
Justin
Old May 25, 2005 | 06:00 PM
JohnQGearhead's Avatar
Car Info: '00 RS, Subrosa Letum
First gear does get a little stubborn sometimes. I only put it into first when I am completely stopped. If you get a short shifter it may get a little more stubborn.
So, YES. This is very common.
Old May 25, 2005 | 08:30 PM
jlam86's Avatar
so messed up! when I"m approaching a red light and it turns green, it stays in second and there is nothing i can do. how does everyone accomodate this? I'm a new stick driver so tips would be helpful. I find clutching in to the friction point and applying more gas normally gets the car moving. but other then that, i'm kinda stumped
Old May 26, 2005 | 03:18 PM
laoba's Avatar
Car Info: rx8
try double clutching and a tiny rev to help it get into first. i find when my tranny is cold it doesn't like going into 1st either; in fact it grinds when it's cold and i put it into 1st. after a while when everything's warmed up it will shift into 1st like a champ at slow speeds.
Old May 26, 2005 | 03:52 PM
jlam86's Avatar
thanx for all the replies. I'll try the double clutching that every is suggesting. I'm new with manual so I appreciate the comments.
Old May 26, 2005 | 04:50 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Double clutch and rev match it, slides in like butter. . . Good luck
Rush
Old May 27, 2005 | 11:49 AM
DaveŽ's Avatar
Rev-matching works, too. Usually what I do if I'm rolling to a stoplight that might change, is let the clutch out in 2nd gear and engine brake for a second, then it pops right into 1st. This works at 20+ mph for me on my WRX.
MotioNz21
Aug 6, 2013 12:59 PM
MotioNz21
Aug 5, 2013 11:29 AM
blkwagon
Show and Shine
Feb 13, 2012 02:55 PM
MrMakesItRain
Feb 24, 2009 11:12 PM
Nose Nuggets
Jan 21, 2006 08:42 PM
