Getting ready for hot summer?
Old May 20, 2003 | 07:26 AM
capt'n'caveman's Avatar
Car Info: platinum rex wagon
how bout slapping on an oil cooler? or if you don't wanna spend as much money, get yourself an intercooler sprayer kit
otherwise, your plan looks good
Old May 22, 2003 | 07:13 AM
DeliciouSpeed's Avatar
Turn off the AC.
Or run a higher water mix in the coolant with redline water wetter.
Get a radiator shroud.
Or get a higher capacity radiator.
Or do them all.
I run a 70% water mix and have a shroud. I've removed MY AC.
k2
Old May 23, 2003 | 12:47 PM
A CAI will do what?
Keep the heater on
I drove across the south in a car nearly over heating like that, And I made it , It's ghetto but it works.
Old May 24, 2003 | 04:19 PM
ScoobyBoy's Avatar
good ole san francisco weather...always chilly and cloudy.
but ive just bought a tranny cooler for my baby just in case.
id say go for the ic spray along with all the radiator cooling methods . thatll help alot, when i was in hayward i would sprinkle some water into the intercooler before i left, so i wouldnt have much of the lovely heat soak.
Old May 24, 2003 | 04:31 PM
240sxer's Avatar
which raditor do you guys recommend? and what is a shroud? is that the fans?
Old May 25, 2003 | 03:03 PM
BlueGargantua's Avatar
Along with a larger radiator you could consider a different "cooler" thermostat and higher pressure radiator cap.
The newer Fluidyne radiators are (correct me if I am wrong) 5 layers thick. The MRT or PWR radiators are 3 layers thick. The Fluidyne is of course a more $$$ as compared to the MRT which runs about 400 approx.
240sxer a shroud is just that aluminum top piece that goes on top of the radiator itself and in theory it forces the air from going over the top of the radiator and allows more air to go through the radiator. Its a simple piece that cost as low as 25 bucks or so.
Old May 25, 2003 | 03:15 PM
240sxer's Avatar
what would you go with for the most cost efficent.
i dont need the mother of all cooling, just something a lot better then my 93L raditor which companys should i go with for a better themostat and hi_pressure cap..
Old May 25, 2003 | 05:14 PM
240sxer
Some folks have experienced radiator problems with the addition of the high pressure radiator caps, ie splitting plastic caps and such. Thats what I have read on at least 6 or 7 posts on the "other" subaru online club. So it might be advisable to get a aluminum radiator first IMO.
I duno if the L radiator has a reputation that the Wrx does with being somewhat weak in construction. If I were you I would try the "water wetter" stuff first.
Thermostats? hmm I have not done that mod yet. but zerosports makes em.
Old May 25, 2003 | 08:03 PM
240sxer's Avatar
what is the water wetter stuff? what does it do? also which raditor do you recommend i get?
Old May 25, 2003 | 09:12 PM
"Water wetter" is a name brand product (redline I think?)and there are several other coolant types out there that claim to do the same thing. Your local NAPA parts house should have it. There may be a write up on it on some thread somewhere. It makes the coolant/water's molecular structure more adaptable to the pores in the metal. thereby allowing heat to transfer out better or faster. Its a neat theory and product once again I am no metalurgist nor engineer so .... a better explanation could be had.
Regarding the radiator: Some guys might tell you that you dont "need" and aftermarket one. My self I didnt look at it as if I was seeking it as a horsepower performance piece. I bought it cause when the weather here in Sacramento got into the 100's my WRX just seemed too hot and the idea of 40% more cooling capacity appealed to me. I bought and MRT cause it was on sale at the time for 375.00. The PWR radiator is of the same caliber as well. (both Australian made and are almost identical) solid alminum nice craftmanship too.
The Fluidyne radiator may be superior in cooling capacity, however, you might pay upwards to $500.00+ . Fluidyne makes a nice product which are fitted into race vehicles.
Old May 25, 2003 | 10:30 PM
240sxer's Avatar
same here i want for the larger cooling capacity... oh yeah and when ever my fan kicks in my idle becomes really unstable.. it drops all the way to around 2-300 rpm sometimes. and very rarely drops so low it turns my car off.. anyone help me with this..
Old May 26, 2003 | 05:55 PM
PWR and MRT have GC8 Radiators. Simply changing the fluid ratios and adding water wetter may suprise you though, try that first.
Kami Speed
Exterior / Interior Lighting
Nov 27, 2007 11:56 AM
subablunc
Jan 10, 2006 08:54 AM
Subman
Apr 17, 2004 08:08 AM
luckistryke
Oct 16, 2003 12:51 PM
