Gasoline smell in cabin
Old Jun 20, 2007 | 03:51 PM
luktang's Avatar
Car Info: 04 PSM WRX
I was driving this morning and notice smell of gasoline in the cabin. I had my AC on. Is there a problem?? Just wanna know. Car is approach 60K. Modded Stage 2. Thx!
Old Jun 20, 2007 | 08:14 PM
Choku Dori's Avatar
Car Info: Corvette Z51
If only you had written "GAS smell in cabin", one of us could have claimed responsibility!
Was the smell coming out of the vents? And did it start at the same time as when you turned on the AC, or was while the AC had been running for a bit?
Old Jun 21, 2007 | 09:20 AM
808subaru's Avatar
Car Info: 09 xt
have you recently installed anything? a new fuel filter, fuel pump maybe? Can you check in the backseat, see if it smells back there. Hopefully you don't have a leak.
Old Jul 6, 2007 | 06:56 PM
taerron's Avatar
i don't believe that the 04 were subject to the fuel leaks that the 02's were. u might want to check your fuel lines under the intake manifold. did you install a fuel rail or anything like that?
Old Jul 8, 2007 | 04:28 PM
WRX409's Avatar
Car Info: 04 WRX
It is possible that one of the hoses coming from the
fuel filter came loose and is causing the smell.It happened
to me once check for a gasoline leak.
RAGEWRX
Dec 23, 2004 07:59 AM
Salty
May 19, 2004 10:40 AM
namitherussian
Feb 5, 2004 11:06 AM
TurnWRX
Jan 3, 2004 11:51 PM
jrod9707
Mar 25, 2003 04:49 PM
