Gas to use?
Old Sep 18, 2005 | 08:54 AM
scotts05's Avatar
Car Info: 2005 Subaru Impreza WRX
Talking Gas to use?
On my fuel tank it says "Premium Unleaded Only", does that mean I can use both premium and unleaded or I use the lower grade of premium?
Old Sep 18, 2005 | 09:29 AM
BillJC's Avatar
Car Info: 02 WRB WRX
Premium means 91 octane unleaded or better. Don't run anything less or you're engine won't run right.
Old Sep 18, 2005 | 11:06 AM
scotts05's Avatar
so your saying i should run premium atleast 91 or better
Old Sep 18, 2005 | 11:26 AM
slvrsubywgn's Avatar
100 octane...woohoo!
Old Sep 18, 2005 | 12:37 PM
BillJC's Avatar
Exactly. running less than 91 causes detonation under load which will cause your ecu to retard timing and richen the ratio. The car will run like a fat pig. You will be boosting about only 7 psi max because the factory boost controler will be shut off ad you will only be using the wastegate on the turbo which opens at about 7 psi. It's not a good thing.
se0ul
Jan 31, 2005 10:36 PM
kidatari
Sep 9, 2004 12:22 AM
nachomc
Jun 1, 2004 11:20 AM
trebsrex
Oct 5, 2003 12:18 PM
yapster
Jul 22, 2003 01:24 PM
