Gas smell at cold start
Old Oct 22, 2012 | 04:34 PM
colt10's Avatar
When I start my car in the morning before work when I get on my car it smells like gas really bad and I see no fuel leaks but gas mileage is kinda getting bad was around 30ish on freeway now around 20-30 on freeway. Anyone had the same problem?
Old Oct 22, 2012 | 04:41 PM
04caliwrx's Avatar
i bet you have a leek on one of the injectors.. cause 10mpg less is a huge loss
Old Oct 22, 2012 | 05:12 PM
02RS25's Avatar
happens to me. but thats because my ODO is at 240k and valve stem gaskets are failing bad.....1-2 qts per week.....
Old Oct 22, 2012 | 05:40 PM
colt10's Avatar
Thanks for the info. How would I go about checking and seeing what injector is leaking ?
Old Nov 1, 2012 | 02:43 PM
Ray#37's Avatar
Car Info: 2002 wrx wagon
The problem you are having sounds exactly like what was happening in my bugeye, cold weather starts especially with the heater on made mine reek of gas. Subaru had a recall for this starting in 09, it was sent to all known owners of these model years, so if your not the original owner and did not receive a recall letter from SOA, try calling your local dealership.
Old Nov 1, 2012 | 02:50 PM
Ray#37's Avatar
But if your loosing 10mpg it might be something alot more serious than that and there is also another post on here under maintenance/warranty 02/03 wrx gas line recall
Old Nov 1, 2012 | 04:15 PM
luckyWRX777's Avatar
Car Info: 2003 WRX Bugeye
I had a problem like yours, took it to the dealership, they fixed it. Forgot what it was, but it was free because of a recall part.
Ill look for the invoice.
Old Nov 1, 2012 | 07:57 PM
subymobbin303's Avatar
Car Info: Foz
if you have an 02 or 03 it could be a gas line recall,
https://www.i-club.com/forums/suby-s...recall-225167/
Old Nov 1, 2012 | 08:44 PM
mendowagon's Avatar
Car Info: 05 wrx wagon
+1 for the gas line recall. I'm the 3rd owner of my 02 wrx and SOA spoke with my dealer and I got all the parts and repair covered under an old TSB/recall
Old Nov 12, 2012 | 07:29 PM
colt10's Avatar
Thank guys I took it in and it was a leaking fuel line it was leaking really bad and I didn't have to pay a dime thanks for all the help everyone
Old Nov 27, 2012 | 02:39 PM
apexwagon's Avatar
Car Info: Sti hatch
+1 on this. or, if you have recently changed the fuel pump, check the gasket on the gas tank. but most likely the all-to-common injector leak.
Old Jan 9, 2013 | 01:09 PM
02RS25's Avatar
+3 on this. taking mine in for same issue. 02RS. i know its a revive, but its a common issue/recall. schmeh
Old Jan 15, 2013 | 11:21 PM
Heedz's Avatar
Nobody likes the tuna here
Glad mine was fixed prior to me receiving the car.
WD93Xx
Jan 22, 2013 08:03 PM
VRWRX
80
Aug 28, 2011 01:26 PM
kidatari
Sep 9, 2004 12:22 AM
Munashi
May 6, 2004 04:42 AM
jrod9707
Mar 25, 2003 04:49 PM
