Gas Gauge Problems
Old Aug 16, 2009 | 12:33 PM
Exclamation Gas Gauge Problems
So normally when I go to fill up my tank with gas I let the pump do its job till it "clicks" signaling that its full. Typically I'll give to a quick squeeze or two more.
Then I hop in and start the car, then reset the trip odo. Normally the gas gauge will reach the top if not slightly over the F. Last night I did the same I always do but when I started the car, the gauge never reached the F level.
Typically ill get anywhere from 75-100 miles once the needle hits a quarter tank (depending on driving style and freeway/city). Well last night I had to go pick up my fiance in Elk Grove (70mph the whole way there and back with no major accelerations). So now my trip odo has 60miles on it from the time I got gas and its already just below quarter tank..
Ideas?
Old Aug 16, 2009 | 12:55 PM
knock's Avatar
Car Info: bici putas
Gas stations aren't laboratory consistent, and the flow rate of each pump will vary depending on a bunch of variables such as filter cleanliness etc. etc.
The pump shuts off when it senses fuel coming back into the nozzle, so this may have happened prematurely because of excess fuel foam coming back because of a higher than average flowrate.
My mom's boxster does this if you don't stand there and hold the nozzle. It's spout doesn't keep the nozzle perpendicular, so the shutoff system is ultra sensitive.
Old Aug 16, 2009 | 01:23 PM
Makes sense.. but 95% of the time I fill up at the same station every time.. and thats where I filled up yesterday as well.
Do the pumps constantly change? Or would you usually seem to have problems with the same pumps?
Old Aug 16, 2009 | 03:28 PM
knock's Avatar
hmmm I dunno really. That's happened to me before and I came up with a possible cause, which is only my opinion/theory/possible B.S. I'm not a gas pump technician
All else I can really say is to check your evap system if this starts to become a frequent occurrence?
Old Aug 16, 2009 | 05:40 PM
Ya, im hoping it was just a fluke this time.. ill update next time I fill up
Old Aug 25, 2009 | 11:15 PM
well tonight i filled up at the same station and same pump that i did last time.
Last time must have been some fluke cuz everything went fine tonight
Old Aug 27, 2009 | 11:25 AM
DemonPossessed's Avatar
Car Info: 05 wrx
i hope everything stays working properly but if it does happen again it could be the floater on the fuel pump assembly. check to see if the arm is working properly.
Old Aug 27, 2009 | 12:52 PM
yea if it happens again anytime soon ill have to take a look at it
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
kidatari
Sep 9, 2004 12:22 AM
scobaru
Aug 8, 2003 05:23 PM
danny b
Mar 2, 2003 06:03 PM
