Fuel Surge?
Old Feb 8, 2013 | 08:10 AM
esousa22's Avatar
Originally Posted by Heedz
Yeah check all your vacuum and boost lines asap. Get that forum crap off and put the cobb OTS map back on, I don't like those but it is probably way safer than the tune youre on now.
Yeah, I should probably do that.. I'll pull a Cobb map off their site and flash it over with a tatrix cable. And why check my vacuum/boost lines? What are you telling me to look for? Leaks? or oil in the lines? or..?
Originally Posted by Shayhan27
Aaaahhh and the light shines in with illumination.
So the situation is more like
Got some parts changed my DP threw on an internet tune and went for it.
Not trying to be a smart ***, but yeah your ecu is probably limiting you pulled some timing. I dont think it would automatically pull boost though. Get an AP with an OTS that looks like it will match, or go to a shop that will tune opensource and just get a protune.
With how much motor replacement is on these I just prefer to always play it safe. I learned my lesson early about putting on parts without a tune, or putting on parts that my AP didnt like. I didnt pop a motor but my car ran pretty poopy with some of the stuff I did.
I didn't consider that being an issue at first so I didn't mention it. I've never had problems with my car at all and I've had the exhaust/map combination for almost a year now and hit redline many times without problems. This is the first time I had a slight issue. I plan on getting a protune within the next month or two if money allows it.
Old Feb 10, 2013 | 01:12 AM
Heedz's Avatar
Nobody likes the tuna here
Wait you're open source? Dude go get a proper tune from someone. Even a TP map or whatever, PM Procede he was running their maps. It's like $175. Check all your lines to see if you have any boost/vacuum leaks. If you have oil in those lines your car is probably ****ed anyways.
Hit redline many times? I dunno.... I just have no words for that one when the map wasn't meant for the mods.
Old Feb 14, 2013 | 01:46 PM
esousa22's Avatar
I'll get a proper tune within the next couple months if repairs don't pop up. I'e heard of oil going in the lines but heard that its not a MAJOR issue and you just get a oil catch can. I'll pm you the link to my map and the source
Old Feb 28, 2013 | 11:24 PM
esousa22's Avatar
So.. I did a 3rd gear pull today and I'm still having this problem. I really don't know how to describe it. Kind of like when your bottom bracket is bent on your bicycle and it just feels a tad off. The car kind of hiccups. Not a significant thing that anybody can notice but if you sit tight as I pull you can feel the car pull 100% then back of to 95% and back to 100% if that makes any sense.
Old Mar 1, 2013 | 12:20 AM
Heedz's Avatar
I dunno, I have this issue sometimes too, but that's because I mix fuels.... Have you tried throwing maybe a gallon or 2 for a full fill up of E85 or maybe 2 of 100?
Old Mar 1, 2013 | 08:33 AM
esousa22's Avatar
its probably been 10 tanks since Ive thrown e85 in it
Old Mar 6, 2013 | 12:36 AM
esousa22's Avatar
cleaned my MAF sensor around 6 and took it for a drive just now and did a couple pulls and it seems to have fixed the issue but I'll post again in a couple days when I know for sure.
Old Mar 7, 2013 | 02:16 AM
Heedz's Avatar
clean air filter too?
Old Mar 7, 2013 | 09:42 PM
esousa22's Avatar
not yet, gotta buy the lubricant and whatever needs to be done to clean a K&N filter. Haven't looked it up yet what needs to be done to clean them nor have I talked to anyone about it. MAF seems to have fixed the issue though
Old Mar 8, 2013 | 07:44 PM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
When you say k&n you are talking about a drop in right not the typhoon.....
If you are talking about the typhoon that thing sucks....
Oct 17, 2005 04:11 AM
JohnB
Jun 30, 2003 12:14 PM
Chris04WRX
Jun 5, 2003 10:21 AM
RshaoKh
Apr 29, 2003 11:28 PM
RshaoKh
Feb 16, 2003 10:40 AM
