Fuel Rail
Old Oct 20, 2003 | 07:47 AM
WickedWRX's Avatar
Car Info: Silver 2002 WRX
Fuel Rail
I've read about problems with the 3rd injector (i think) not getting as much fuel as the rest of the injectors due to the stock fuel rail. My question it can I upgrade my fuel rails (perrin) and keep everything else stock? If not what else should I get? All i'm doing to the car is a turbo back exhaust, uppipe, and a few other minor mods.
Old Oct 20, 2003 | 09:51 AM
international B's Avatar
Chewwwwy
you can upgrade the fuel rails, however. most fuel rail systems get sooo much more fuel to the injectors, that the car would run pig rich. you will need to atleast run a fuel pressure regulator other then the stock one so you can get the correct mixture.
if you are not going to turn up the boost at all, then dont even worry about the fuel rails.
Old Oct 20, 2003 | 01:00 PM
4080wrx's Avatar
with that said would you need the fuel rail upgrade when running a cobbstage 2. sorry to hijacked your thread wickedwrx
4080
Old Oct 20, 2003 | 01:23 PM
WickedWRX's Avatar
Hey, that's is perfectly fine with me cause I was wondering the same thing.
Old Oct 20, 2003 | 01:35 PM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
No. You just need to upgrade your fuel delivery method. The WRX (and most all subarus as far as i can recall) run in serial; that is: from the filter down to the rail on the drivers side, then over to the rail on the passenger side, out thru the regulator then back to the tank.
The main benefit of the perrin rails is not that they flow more fuel, but that they change the flow pattern to parallel. from the filter to both rails, back to your regulator, then on to your tank. You can do this yourself with some spare weekend time, some fuel line, and some know-how.
The stock fuel rails flow plenty. So much in fact, that the easy-street WRX uses a modified stock rails.
stupidchicken03
Jun 18, 2014 02:13 PM
STi_Mark
Jan 31, 2007 03:38 PM
Orbiter
21
Dec 21, 2004 04:39 PM
azscoobie
Mar 12, 2003 11:11 PM
PunksWRX
15
Dec 30, 2002 12:31 AM
