Aftermarket fuel rail confusion/questions???
Old Dec 28, 2002 | 07:45 AM
stealth-wrx's Avatar
get the vishnu and you will be fine up to 500 hp
Old Dec 28, 2002 | 10:24 AM
nqwan's Avatar
Car Info: o2 duburu arr exu
unless you try to swap in avcs heads.
Old Dec 28, 2002 | 04:09 PM
bamfwrx's Avatar
Car Info: 02 WRX
Why will vishnu rails not work with avcs?
I was planing on getting some fuel rails soon will any of the others work on a ver7 engine?
Old Dec 28, 2002 | 05:21 PM
nqwan's Avatar
they wont physically clear the avcs heads due to the way they position the injectors. they were designed for the gc8 iirc, so they dont position the injectors exactly like the stock fuel rails. the perrin's do however and will clear the avcs heads. i'd imagine the mrt's would as well but i dont have any knowledge of anyone trying that setup as of yet so i dont know for sure.
Old Dec 28, 2002 | 07:30 PM
bamfwrx's Avatar
Car Info: 02 WRX
Thumbs up
thanks
Old Dec 29, 2002 | 11:34 AM
now when you say that the injectors are positioned correctly how does it make a difference if the injectors are turned 90 degrees.
now if it made any difference do you think shiv would have made his fuel rail they way he did. vishnu would never come out with a product unless they didnt think it was perfect.
Old Dec 29, 2002 | 05:29 PM
damn, too bad i bought the vishnu rails. more money i have to spend. this sucks bad. the sti housings still have the splitting. i know because i have the sti ones.
