fixing up 04 WRX in cali.
Old Jul 26, 2003 | 02:43 AM
downshift's Avatar
Car Info: dream car Subaru STi
ok guys i was wondering.. if i got $1500 and i want to make my bone stock 04 WRX be fast. what are cheap mods i should buy to make my car run 13's. need expert advise please
-mike
Old Jul 26, 2003 | 01:53 PM
ish's Avatar
ish
upipipe, downpipe, exhaust and mbc
you could probably do that for 1500
Old Jul 26, 2003 | 02:14 PM
bone324's Avatar
Car Info: '02 WRX WRB
I would go with a TurboXS turboback and Cobb ECU reflash. The reflash covers way more than just boost levels (plus you don't need a boost gauge). That should be possible with $1500. After that uppipe, IC hoses, and pulley will pretty much max out the stock turbo.
Old Jul 27, 2003 | 03:12 AM
downshift's Avatar
what is a turboback and how and where is the cobb ecu reflash done at?.
Old Jul 27, 2003 | 08:24 AM
BlkRx's Avatar
Car Info: 2004 Black Wrx
Turboback is the exhaust from the turbo back to the muffler. And as far as the reflash goes I think that you send your ecu to cobb.
Old Jul 27, 2003 | 09:06 AM
bone324's Avatar
Not to be offensive or anything, but how is it that someone can have 461 posts on i-club and not know what a turboback is? The Cobb ECU reflash is done at Cobb's shop in Utah. You send them the ECU next-day and they send it back the same way. Three days of down-time. They plug it into a computer, reprogram it to a predecided map (based on your mods and gas octane you have available), and then unplug it. The entire process takes less than 5 minutes. It only costs $400 compared to ECUtek from Vishnu, RallyPerformance, and others for $800.
Old Jul 27, 2003 | 10:20 AM
GEARHEAD's Avatar
Thumbs up yes
there is a reflash for the 04
Old Jul 27, 2003 | 02:09 PM
downshift's Avatar
ohh i c.. haha well i like to posts a lot t o learn more, cause i have lots of questions.
thanks for the info, about the reflash, but doesnt the ecu automatically adapt to the new mods on the car?
Old Jul 27, 2003 | 02:19 PM
bone324's Avatar
To a certain degree, yes. The ECU will adjust to different conditions brought about by mods. However, the reflash will address several things that the stock map will not change or only change slightly. Just a stage 1 reflash with everything else stock is good for 20+ hp. Some Subaru dealers are offering Prodrive performance packages for the WRX which include reflashed ECUs. So, that should be some indication of how safe and efficient reflashing can be.
Old Jul 27, 2003 | 11:36 PM
downshift's Avatar
who do i look for if im in los angeles, and i want to fix up my WRX with profesional subaru shops
