Few mod questions????
Old Mar 3, 2004 | 04:21 PM
02wrbluewrx's Avatar
Car Info: 2002 WR Blue WRX
First of all Perrin crank pulley.....Yes/No
Second I can only do one at a time so which first up-pipe or down-pipe
Third does anyone know of any problems hooking a bosal down-pipe to a scooby sport mid-pipe.....thanks everyone
Old Mar 3, 2004 | 07:58 PM
I have heard that the lightened pulleys arent balanced though and can cause problems....also wouldnt i want to let air move faster out first before i cram more air in
Old Mar 3, 2004 | 08:18 PM
ilivas's Avatar
up-pipe is part of the exhaust. You would free up exhaust back pressure by getting an up-pipe.
Old Mar 5, 2004 | 06:13 AM
theworx's Avatar
Car Info: 04 Java Black Sedan
You would see more gain out of a downpipe than an uppipe. However, downpipes are notmally more expensive and if you get a catless one you have to get a way of fixing the CEL. I say go w/ the downpipe first, then midpipe, cat back, then uppipe, then pulleys.
Old Mar 5, 2004 | 06:16 AM
I'd avoid pulleys. Wait til later when you can afford a flywheel for a much better version of the same effect. Pulleys can have some negative effects, especially underdrive ones.
As for exhaust, it's always best to buy one complete turboback as a unit rather than piece together downpipe X and Midpipe Y and catback Z. Also, the faster spool of the uppipe cat being gone will probably make the car feel faster than changing just the downpipe, although top end gains are higher for the downpipe usually. Based on that, I would get the uppipe first.
Old Mar 5, 2004 | 06:17 AM
namitherussian's Avatar
Car Info: Black WRX
get a Helix downpipe it comes with a CEL fix or save up a bit and get Helix combo from MPJ performance
Old Mar 5, 2004 | 12:51 PM
bluwrxwgn's Avatar
Car Info: '02 WRB WRX Wagon
I'd say Uppipe first. You will spool faster that way.
Mobutusan
Apr 2, 2008 11:38 PM
T-Will
Jun 20, 2007 09:24 PM
nycvr6
Dec 22, 2002 12:00 PM
