factory electronic boost control
Old Aug 28, 2006 | 11:48 PM
Jakes02's Avatar
Car Info: 2002 WRX
Question factory electronic boost control
'02 WRX 5sp.
When the car was bone stock it would not boost in 1st gear. This is electronically controlled, correct?
Now that I have my TBE on it will boost up to....not sure I'm busy paying attention to the road but I've seen the needle pass .05mpa (and assume it makes it to .09mpa)
Is thier something wrong or is this normal with an aftermarket TBE?
Old Aug 29, 2006 | 10:01 PM
Jakes02's Avatar
Car Info: 2002 WRX
yes....no....maybe......shutup???
Old Aug 30, 2006 | 10:18 AM
AJBoost's Avatar
Car Info: C32 AMG, Lincoln Navigator, LS1 Trans Am, E36 Bmw
Under stock EM you WILL boost in first. However, the boost is limited. I believe this was done for reliability from Subaru.
AJ
Old Aug 30, 2006 | 07:14 PM
Jakes02's Avatar
Car Info: 2002 WRX
i never saw the needle pass 0 mpa in stock form.
Old Aug 30, 2006 | 08:46 PM
WRX409's Avatar
Car Info: 04 WRX
Jake that is odd you should see some boost in first gear??
The boost should be very limited though.
Old Aug 30, 2006 | 08:52 PM
Jakes02's Avatar
Car Info: 2002 WRX
Is it normal to hit full boost in 1st with a TBE?
Old Sep 2, 2006 | 05:53 PM
fenderstrat066's Avatar
Car Info: 2004 Wrx
No, you should not be making 1bar or .1mpa (or w.e the stupid lampco gauge reads in) in first gear. Although first gear on these cars pulls like hell its only about .7bar. In every other gear the car makes more boost.
Old Sep 3, 2006 | 08:07 AM
Jakes02's Avatar
Car Info: 2002 WRX
hmmm thanks for the info.
saintseiyaz
Apr 28, 2011 09:57 PM
John OBrien
Engine and Drivetrain
May 7, 2009 10:03 AM
Wrxplaya11
Nov 6, 2003 09:54 PM
JDM SiR
Jul 24, 2003 04:35 PM
Astacun1
Jun 28, 2003 03:12 PM
