Factory Boost Gauge Accuracy
Old Jul 23, 2003 | 09:43 PM
escaflowne's Avatar
Car Info: 2004 Black WRX wagon
i have one too. but it's on my 04. seems pretty accurate. i don't like that it uses mPA instead of PSI or regular KpA. oh well.. it looks cool hahaha! i'm actually thinking about changing the face of it... haha.. pretty rice. haa
Old Jul 24, 2003 | 08:10 AM
blubaru's Avatar
Car Info: '02 WRX wagon
Re: Factory Boost Gauge Accuracy
Originally posted by twright55
One possible issue is that when the engine is off, the needle sits at the bottom of the BROAD white line that marks '0'. I estimate that this line is about .01 thick. Perhaps my gauge is not properly 'zeroed'. That would still only put me at .09 or 13 psi.
I have the same problem with my aftermarket Omori. The needle with engine off is below the zero mark and I'm only seeing max boost of ~12.5 psi. From what I've read on here should see at least 13.5 psi.
If yours was installed before you bought the car, 3 year warranty applies. If not, you may still have parts warranty. Discuss this with your Subaru Service Dept.
Old Jul 26, 2003 | 04:08 PM
2Stroke's Avatar
Car Info: 2003 WRB Wagon
The factory gauge on my MY03 WRX does the same thing. I think it's at least partly because I'm above sea level most of the time, and it's a mechanical gauge.
Next time I'm at the beach, I'll try to remember to see if it zeros.
If this is the reason, it ought to to sit noticeably below zero at high elevations. Has anyone seen this?
In terms of accuracy, the numbers agree very closely with my OBD-II scanner. When comparing the scanner's numbers to my visual observations of the gauge, the biggest source of error comes from me reading the gauge.
If I had to put a number to it's accuracy, I'd say it's good to within .5 psi or less.
joltdudeuc
Jul 30, 2015 08:32 AM
bcarleton
Nov 23, 2006 07:44 AM
SteveJ
Jul 21, 2003 02:15 PM
mattr762
Apr 18, 2003 09:12 AM
keith
Mar 11, 2003 01:30 PM
