exhaust system question?
Old Dec 25, 2003 | 08:47 PM
DWNSHFT's Avatar
Car Info: 03 sedan 2nd wrx
I have a 3" top secret turbo back catless jdm And I just put a stock axle back on the car ' I had to mod. out the stock axle back to fit the jdm pipeing' And now it feels like the car has alot of more torqe then with my wide open system why? Is this going to be bad for the car?
Old Dec 25, 2003 | 10:10 PM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
Miguel,
that's what happens when you have some increased pressure.
It's not going to ruin your car, but it is restricting flow with the stock muffler.
-Gagan
Old Dec 25, 2003 | 10:13 PM
my2003wrx's Avatar
You sacrifice top end for the low end grunt.
:banana:
Old Dec 25, 2003 | 10:50 PM
Choku Dori's Avatar
Car Info: Corvette Z51
Increased backpressure often feels like more torque. Think of a .5in tip on a 1 in garden hose: how does the water flow? Same idea with your exhaust. It's not unhealthy, it just limits your car's full performance capability.
What really makes strong torque with an exhaust is a steady, high-flowing column of exhaust gas. The engine has to have enough power to create this phenomenon, and the best exhaust for this is the widest possible before the exhaust gas column loses its density and steadiness.
Our turbo engines easily generate this sort of exhaust, even stock; that's why we do fine with large diameter exhausts that would make a Civic or Integ struggle to pick up.
Do I make sense? Probably not eh? Too much eggnog haha... this was covered in an old Sport Compact Car a few years ago.
Old Dec 26, 2003 | 03:15 PM
trebsrex's Avatar
Car Info: Old Brighton
Re: exhaust system question?
I wanted to do the same setup (turboback,catless,stock axleback)
but if i have to mod the axleback to fit the catback now i'll have to think about it...
Old Dec 26, 2003 | 03:28 PM
my2003wrx's Avatar
Awww, Lambert, are you going to sell your catback? Maybe Don will want it
:banana:
Old Dec 26, 2003 | 03:48 PM
ScoobyBoy's Avatar
do you have this weird squeak with the stock axel back? ive been having that for awhile and its bugging the ish out of me.
Old Dec 26, 2003 | 08:21 PM
DWNSHFT's Avatar
Oh ok so when ever I get it reflashed will the swaping of the stock and the 3" axle back cause issues or will it not matter for reflashing performance?
And no squeking thanks yall
Old Dec 27, 2003 | 05:55 PM
awns729's Avatar
Car Info: want a WRX
i think it depends what reflash you get done and what other mods if any you have
Old Dec 27, 2003 | 10:30 PM
Maniac's Avatar
Car Info: Silver 2002 WRX Sedan
I have APS Mark 1 turbo-back. The dp and mid pipes are all 3", but the rear section is 2.5". This way you get to keep the torque and you get the top end as well. It is a "balanced" system. It makes compromises to achieve the best driveability.
bluesaint
Jun 1, 2006 02:23 PM
My_Red_Suby
Oct 9, 2004 01:03 AM
2K3WRX808
Jun 28, 2004 01:40 PM
bambams247
Aug 26, 2003 05:06 PM
