exhaust for the STI?help me pick
Old Jun 26, 2003 | 06:01 PM
adamRmr's Avatar
Car Info: WRX STi black/Gold rims
Question exhaust for the STI?help me pick
thinking about getting exhaust for my subaru! can you help me pick from the 2 kits i have found.was thinking about #2 cheaper and comes with a up pipe.
THank You
#1 TurboXS Exhaust $1126.
100% Stainless Steel System Designed on our in-house AWD Dynapack dyno for unparalleled performance
4" Mandrel bent T304 Stainless downpipe smoothly tapers to 3" for a smooth laminar flow into a 3" high-flow cat
OEM style doughnut gasket enhances flexibility, durability and sealing as opposed to lower quality flex joints
All components feature a 5 year warranty!
#2 DN Performance $999.00
polished Stainless Steel. It maintains the stock mounting location. High flow 3" stainless steel mandrel bent pipe with no cat. Bell housing design with wastegate block plate available. Direct bolt on. A complete gaskets and bolts are included. Polished Stainless Steel uppipe with high temp coating.Uppipe O2 sensor and EGT fitting.Mandrel bend,Beautiful TIG weld,Match turbo flange
medicSTi
May 26, 2008 01:25 PM
jason bouchard
Wanted
Jan 19, 2006 11:03 PM
fah q
Apr 28, 2004 09:10 AM
98skuby
Jan 31, 2004 10:29 AM
ilmaestro
Jan 14, 2003 02:23 PM
