Exhaust question...
Old Jul 17, 2006 | 11:35 PM
Flippy's Avatar
Car Info: 05 Impreza
Exhaust question...
I installed a HKS Hi-Power catbak exhaust system in my 05 WRX.
My question is that i notice i have a small gap from teh stock cat and teh end piping from teh exhaust. I can feel heat ecaping... Will this cause future problems?Am i losing power? Any solutions would b appriciated....
im still a noob to teh whole wrx thing so ya =/
Old Jul 17, 2006 | 11:42 PM
Jakes02's Avatar
Car Info: 2002 WRX
you will want to fix your exhaust leaks. its at the flange right? tighten the bolts a little more. you should be able to close that gap. if that doesn't work you may have to replace the gasket and try putting the piping together again. short term you will be able to drive. i recommend getting this fixed very soon though
Old Jul 17, 2006 | 11:45 PM
Flippy's Avatar
ya its at teh flange......Bolts are tight as possible...i tink its cause teh piping of teh exhaust is angled a bit
Old Jul 17, 2006 | 11:49 PM
Jakes02's Avatar
Car Info: 2002 WRX
are both of the flanges flush or does one have a lip on the inside. if the bolts are as tight as you can get em then you will have to re-align the exhaust. you will (almost guaranteed) have to get a new gasket cuz one side is probably crushed and it won't seat right after you realign it.
Old Jul 18, 2006 | 12:43 AM
Flippy's Avatar
flush i tink, i took off teh donut gasket and just bolted on teh exhaust with teh given gasket teh exhaust came with...
Old Jul 18, 2006 | 12:53 AM
Jakes02's Avatar
Car Info: 2002 WRX
pm'd . click on private messages in the upper right corner
brucelee
Aug 1, 2009 10:59 AM
Skatemur
Oct 1, 2004 12:56 PM
dj_kiyoshi
15
Jul 24, 2004 12:36 AM
2K3WRX808
Jun 28, 2004 01:40 PM
legacy2003
Jun 8, 2003 04:43 AM
