exhaust problem help
Old Dec 8, 2006 | 01:12 PM
XxPLoSiVexAzNxX's Avatar
Car Info: 04 blue wrx
Hey i have a 3inch catless helix dp and a tsudo catback.. there seems to be some kind of leak in between the downpipe and the catback, maybe because it doesnt mount correctly, but i can hear it when the car is on and driving.. it is some kind of ring noise, from what i know, tsudo is a 2.5 so it might not fit correctly, but there is also a knock from the dp bumping into something. can this be fixed by replacing the mid-pipe with someone else? or even better can it be fixed without replacing anything? Thanks
Old Dec 8, 2006 | 04:05 PM
colorado_sport's Avatar
Car Info: 05 wrx @ stage 2
You can drop your exhaust system unbolt the system and see whats wrong with it yourself. Check to see if you have a gasket it will help to stop the leak.
Old Dec 8, 2006 | 04:13 PM
i do have an exhaust gasket on there, that's why im not sure what it is exactly.
Old Dec 9, 2006 | 11:31 AM
Jake's Avatar
do u have an up-pipe? I experienced an exhaust leak too and usually its from the up-pipe
Old Dec 9, 2006 | 11:49 AM
Cobb05STI's Avatar
Car Info: Cobb Stage 2 Walbro255lph, eibach prokit, RCE camber plates, invidia TBE RACE, Black red lip BBSs
well on install did u tighten everything from the turbo back or did u start from the muffler and work your way up a lot of ppl make this mistake. another one is they leave so much to work with as far as centering the muffler to the mid pipe on a lot of these cat back system witch was my problem my guess is that the 2 flanges where the mid pip and axle back are off center and it is leaking there. so dont center it and fix it go to the auto store and get some exhuast cement and then lay a thin layer on the gasket re-install it and center the pipe while tightening the bolts if u have a lift i suggest having a friend help hold the pipe center it's hard to do on your own but can be done on the ground just jack it up from your diff..
CarbonScooby
May 7, 2011 03:50 PM
matt888111
Feb 29, 2004 11:24 PM
Impreza_WRX_STi
Sep 29, 2003 07:13 AM
JIChawaii
Aug 3, 2003 01:52 PM
