Excessive valvetrain noise?
Old Mar 22, 2004 | 07:51 PM
curbait's Avatar
Car Info: 2002 silver rex
Valves move twice per revolution, rod knock sounds like only once per rev. If it were me I wouldn't drive or start it until I found out whats causing the sound. Start with the valve area and work your way to the crank. Some people would change motor oil to some 50W If the sound lessens or goes away a tear down is in order. With what you got invested I would just start with the heads and work my way in.
Old Mar 23, 2004 | 12:38 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
How is the oil pressure? If you have a rod bearing going away, you'll see low pressure.
What kind of clearances did you see rod-bearing-to-journal?
And the valvetrain runs at half the speed of the crank.
720 crank degrees = 360 cam degrees.
I think a valvetrain problem would be noisy regardless of rpm.
Take the plugs out of the motor and set each piston to TDC. When said piston is at TDC, use a plastic stick or wooden dowel and try to push piston back to BDC thru plug hole. If you feel no resistance and then resistance, you've found the rod bearing that is dying.
Sorry buddy,
Jim
PSBeachBum
Aug 5, 2011 09:17 PM
juicy
Feb 2, 2008 12:29 PM
psoper
Aug 6, 2007 06:18 PM
Sloppy Joe
Oct 29, 2003 12:03 PM
TVA
May 15, 2003 08:24 PM
