Emissions testing
Old Dec 21, 2003 | 11:17 AM
ikes wrx's Avatar
Car Info: 02 wrx
Emissions testing
Just a quick question, What after market exhaust set up are you guys running for the street?
Do you have 1,2,3, cats?
Have any of you failed you emission test? Or have you passed with flying colours with one cat?
Old Dec 21, 2003 | 05:26 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
i have 1 cat and it probably doesnt pass smog
i heard that all 3 cats are needed to pass the test
Old Dec 21, 2003 | 07:39 PM
Daredevil's Avatar
i have 0 cats
Old Dec 22, 2003 | 01:27 AM
If you buy a complete turboback exhaust system that has a high-flow cat, you will almost certainly pass the sniffer test provided your ECU knows how to fire your injectors if they aren't sock. If you have a catless system, you will almost certainly fail. If you remove some stock cats but not others, you fall into the ambiguous area where you won't know until you try. The bad part in that case though, is that you can't truly make gains from exhaust until it's all been changed out for larger piping with a better flange, smoother bends, less restrictive muffler... it all matters.
PurduePhiGam
Jul 29, 2005 02:33 PM
spoooolin
Jul 18, 2004 04:53 PM
harrydog
Apr 14, 2004 08:12 AM
wefarkle
Jun 30, 2003 10:53 AM
ekonizer
Rocky Mountains
Apr 7, 2003 11:18 PM
