Electronic Boost Controller
Old Jun 25, 2003 | 12:29 PM
atcvader's Avatar
Car Info: RIP:2002 WRX/03 EVO/02 Navigator... Hello 2005 LGT WGN
I need a little help. I have the HKS Boost Controller w/ fuzzy logic, and everytime I try to boost over 1 bar it cuts out and starts boosting at .5. Not just first gear, but all gears. What could the problem be and what can I do to fix it.
Old Jun 27, 2003 | 01:45 PM
atcvader's Avatar
can someone please help me.
Old Jul 2, 2003 | 11:48 AM
fastnoypi's Avatar
are you running a stock turbo and stock engine management?
If so , you are running into the factory boost cut.
Old Jul 2, 2003 | 02:36 PM
atcvader's Avatar
Yah, it's a stock turbo. Is there a way I could bypass that cut off, or maybe even just take it off?
Old Jul 2, 2003 | 08:46 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
PM me, and give me your number... Sounds like an improper setup or installtion. I live in SD as well.
Old Jul 3, 2003 | 07:06 AM
fastnoypi's Avatar
A HKS FCD..fuel cut defenser could raise your stock ecu boost cut..but you will not be getting any more power. The stock turbo starts gettting inefficient and blowing hot air at 14.7-15.1 psi (slightly over 1 bar). Try tuning the boost down slightly to its limit.
Old Jul 7, 2003 | 10:23 AM
atcvader's Avatar
This was the latest test. I set it on 1.05 bar and it works fine. Sometimes it would pass 1.05 and that's when it would drop to .05 . So I guess that 1.05 is my limit...
Im Too Lazy
Dec 8, 2011 11:48 AM
John OBrien
Engine and Drivetrain
May 7, 2009 10:03 AM
Wrxplaya11
Nov 6, 2003 09:54 PM
KurleeDaddeeWRX
Nov 5, 2003 06:21 AM
STLscooby
Jan 11, 2003 06:03 PM
