EJ20 Build
Old Dec 6, 2003 | 09:40 AM
misterx's Avatar
Car Info: MY 02 WRB WRX Wagon
EJ20 Build
Take a look at this block. The compression ratio is 9:1 as opposed to 8:1 and it has been described as being detonation PROOF!
A normal Subaru sleeve is around 1.5mm thick. The sleeves in this engine are 115mm thick! A 100mm bore leaves 7.5mm of cast iron in the cylinder wall which means you can have a 2.0L that is WAY stronger than a regular 2.0L. It is completely balanced and blueprinted. Lots of larger displacements can be accomodated, but I chose 2.0 because, well, that's what I wanted.
Magnus Motorsports makes the block. Speak to Marco if you want one too. http://www.magnusmotorsports.com/home.asp
At any rate, I need a set of MY02 USDM heads. Since I'm going to go with JUN 256 cams, aside from the casting, not much else is really going to be useful. Marco is rebuilding using 04 USDM head parts (shimless buckets ).
Should anyone have a line on the heads, please let me know?
X
Old Dec 6, 2003 | 08:24 PM
misterx's Avatar
I'm not sure because I'm doing new gears and the turbo hasn't been chosen, yet. I also expect to need bigger injectors than the STis and, of course, there will be a tune required.
I guess over $12K.
I suppose some guys will roll their eyes and with good reason because there is little reason in this. Except the engine will be built to real race standards and I've always wanted that. Blueprinted, balanced and 9000 RPS.
I can't resist it. :banana:
Old Dec 7, 2003 | 12:15 PM
oldmansan's Avatar
I've been looking at that same block.
How much is just the motor going to run you. PM me if you want.
San
Old Dec 7, 2003 | 01:51 PM
misterx's Avatar
The 115mm is the diameter of the entire sleeve. A 100mm bore leave 7.5 mm of sleeve material.
Old Dec 8, 2003 | 11:39 AM
push2's Avatar
Car Info: 02 GGA
What comes with the $12k? I almost ready to start building but was thinking about going with a built usdm block and using a type c head. The complete type c with tranny and everything I need from the drivetrain is gonna be about $8k after that I'll have to sell my usdm complete setup to pick up any other parts that I'll need. It sounds like your going with what I kinda wanna do. keep us posted.
Ralph
Old Dec 11, 2003 | 09:20 AM
misterx's Avatar
It's not done yet, so I'm not sure.
Old Dec 11, 2003 | 03:33 PM
misterx's Avatar
The 02 heads will fit up perfectly. Since all new parts will be used, shimless buckets and all, and the heads will be ported and polished, I'm confident it will work well.
I'm adding JUN cams, too.
KrIsToY!
Hawaii Classifieds
15
Jun 18, 2010 06:58 PM
turbofreak
24
Feb 3, 2003 11:17 AM
StankFootZ
Jan 3, 2003 12:24 PM
Tifosi77
Nov 28, 2002 02:05 PM
