downpipe installation
Old May 19, 2004 | 10:58 PM
pleue's Avatar
Car Info: 2002 4EAT MBP wrx wagon
hey everyone,
Just picked up a used bosal downpipe (for $50 :-D ) and was wondering if you all had any tips for doing the installation? I have basic tools/knowledge, but a lack of directions since it is used. I tried searching around for directions, but couldn't find any. Should I spring for new gaskets from the dealer or can I get by with the old ones (33k miles)? What do I torque the bolts to? any help is greatly appreciated.
Old May 19, 2004 | 11:01 PM
bassplayrr's Avatar
From what I understand, a whole new gasket set is ALWAYS a good idea. SubyDude.com has them, and at a good price. For the instructions you can try searching scoobymods.com. I think the install instructions are by Perrin, but obviously will work for any UP. I would also reccomend getting a Down Pipe and putting tht on at the same time since the DP has to come off when installing the UP. Good Luck!
-Chris
I kept thinking Uppipe... so ignore my post. If you are ever wondering about an Uppipe install then what I said is true. ;-)
Old May 20, 2004 | 06:11 AM
Wingless Wonder's Avatar
Check out Egan's downpipe install page, complete with pics.
Old May 20, 2004 | 08:54 AM
dan avoN7's Avatar
2006 Mt Hammy Car Show Winner
Car Info: Black 03 WRX, White 04 E46 M3
downpipe is really easy. Just jack the car up, take off the heatshield, remove the 5 bolts from the turbo to downpipe then the 2 from the downpipe to catback. Then remove the rear o2 sensor and take off the dp bracket bolts. Once all bolts are off you get a screwdriver and pry that bracket type piece off that holds the dp in place. Then just reverse the order and your all done. Shouldn't take more than an hour to an hour and a half, but ive heard stories of some noob taking 6 hours....
Old May 20, 2004 | 09:11 AM
willow's Avatar
Car Info: wrx02
Old gaskets will work find for downpipe to turbo installatuion. I did w/o it. No leaks. I would recommend trying to get downpipe to transmision bolt loose 1st. Don't know what kind of tools you have, but I needed to go buy a skinnier tool for that bolt. Its bracket just gets in the way.
Old May 20, 2004 | 10:21 AM
DanyoCantDrift's Avatar
The weal amewican hewo!
question for everyone...i installed my downpipe and exhaust this last weekend and took off the heat shield and left it off...its that ok?? or is it really essential...i was reading the link that wingless wonder posted and egan said something about preventing melting wires and reducing intercooler heat soak....should i put it back on??? danx
Old May 20, 2004 | 11:55 AM
pleue's Avatar
do i need an o2 sensor wrench? is that somerthing you can rent at kragen or something?
Old May 20, 2004 | 12:43 PM
SnoHumper's Avatar
Car Info: sc300
you can get the o2 sensor off from midpipe with a big open end wrench i forgot what size, but its easily accessable, unlike the damn header one. as far as the gaskets, get new ones but not from the dealership becaues you will be paying twice as much.
Old May 20, 2004 | 02:44 PM
dan avoN7's Avatar
you dont need to replace the downpipe gasket. It is very rare for that to leak, ive taken off my downpipe about 3 times since putting it on and have never had leaks. The exhaust manifold to uppipe should be changed though when installing an uppipe since that area is known for leaking.
Old May 20, 2004 | 05:04 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Heat shield = good. The hot turbo will heat your IC quicker, as well as brown up your firewall. Search around, there's an easy way to trim it to make it fit well with aftermarket DP's.
Turbo86
Sep 21, 2005 06:34 PM
azn_wrx
Jun 12, 2005 07:07 PM
mwahaworld
Sep 29, 2004 10:54 PM
My_Red_Suby
Aug 21, 2004 10:08 PM
Puguglies
May 18, 2004 07:30 AM
