downpipe cell fix installation tips???
Old Sep 21, 2005 | 10:11 AM
Turbo86's Avatar
Car Info: 2003 WRX Sedan
Question downpipe cell fix installation tips???
so installed a downpipe on my car last saturday and it was getting late so i skipped the cell fixture. i bought the helix downpipe from gruppe-s so they included the cell fixture for me.
i'm just wondering what the best way to install it is. a few people have said that soldering it is the way to go, but i have a feeling ill need to take it off for emissions testing so could i just use wire connectors or just twist the ends together like speaker wires and cover them with electrical tape?
thanks
Old Sep 21, 2005 | 10:16 AM
mbquarts's Avatar
Car Info: 03 MBP WRX
Soldering will give you the best connection, but wire connectors will be the most convenient when its time for a smog check. I used some standard wire connectors so that I can unplug the cel fix whenever I want to. I covered the whole thing with electrical tape as well to keep the wires from chaffing and shorting out.
Old Sep 21, 2005 | 10:37 AM
Turbo86's Avatar
now obviously i'm going to have to cut the original wires to install the cell fix, what happens when they do the visual emissions inspection? will they give me a "no pass" if it looks like the wires to the o2 sensor have been tampered with?
i'll prolly just go the wire connector route, i'm assuming i can get those pretty cheep at a radio shack?
thanks
Old Sep 21, 2005 | 01:51 PM
mbquarts's Avatar
Most likely they wouldn't even notice that the wires were cut. To be on the safe side cover the connectors with electrical tape before you take it in to be smogged. Yeah, the connectors only cost a few dollars from radio shack or most hardware stores.
Old Sep 21, 2005 | 05:08 PM
slvrsubywgn's Avatar
Or you could just install the mechanical fix.
Old Sep 21, 2005 | 05:32 PM
Turbo86's Avatar
can someone please explain (in detail) what this mechanical fix is? im very interested to know, everyone keeps talking about it, is that the way to go?
Old Sep 21, 2005 | 05:41 PM
laoba's Avatar
Car Info: rx8
i thinks its gp moto that makes the cel fix.i think im wrong though, i forget exactly who it is. it screws into your o2 bung on the dp and the sensor goes on top of that.
Old Sep 21, 2005 | 06:34 PM
Here's the thread that helped me the most.
https://www.i-club.com/forums/showth...hlight=cel+fix
This is the home made version. I don't know which manufacturer makes one to sell, but this one only costs 4-6 dollars. Very easy to make, well worth the time and money in my opinion. Plus you can leave it screwed into your aftermarket dp permanently and you don't haveto worry about messing with wires, shorts, or if you're going to pass smog or not. I've been running completely catless (and no type of reflash or em) and have not had a check engine light come on yet.
NemoSuby
Mar 25, 2012 10:49 AM
BoostBuddy.com
Engine and Drivetrain
Feb 20, 2007 07:02 PM
mitchsti
Nov 2, 2006 10:10 AM
hockeygod
15
Dec 5, 2004 11:11 PM
wj36
14
Jan 3, 2003 07:54 PM
