Downpipe Brackets
Old Aug 1, 2003 | 10:18 PM
VF22WRX's Avatar
Car Info: '02 WRX Sedan
Downpipe Brackets
I just installed an Invidia dp and I couldnt align the tranny bracket or the rear bracket well enough to bolt them up. The pipe lined up just fine to the turbo and catback...no leaks. The real problem is that the brackets are rattling quite badly...would it be ok to just cut them off? Thanks in advance.
Old Aug 1, 2003 | 10:23 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
The rear bracket can be removed with two bolts. The front bracket is a different story. Cut it.
Old Aug 1, 2003 | 10:26 PM
VF22WRX's Avatar
Do you mean the rear bracket on the car? I was talking about cutting the two brackets off the dp itself.
Old Aug 4, 2003 | 01:30 PM
boloheadrat's Avatar
My Invidia only came with the rear bracket welded on-- that doesn't line up. It is the second version of the DP, but it seems to be pretty secure without the bracket. The bracket teiva-boy is talking about is on the car, which the rear dp bracket bolts to. If you take this off you won't have to cut off the rear bracket... As for the front... Well you better go get your hack-saw.
StealthMODE
Aug 14, 2014 03:09 PM
sunnys25
Wanted
Feb 5, 2003 10:36 AM
Dapper
Jan 22, 2003 12:32 PM
whiterabbit
14
Dec 7, 2002 06:29 PM
