Downpipe with Borla?
Old Mar 31, 2004 | 08:53 AM
TroyBoy24's Avatar
Car Info: 03 sliver WRX
hey guyz, i have a borla hush cat and i recently got my helix flex uppipe installed. I was wondering if someone could help me on finding a downpipe that would fit with my borla hush, maybe even a downpipes with a high/flow cat.
thanx
Old Mar 31, 2004 | 01:00 PM
myroncuz's Avatar
i believe pde will fit
Old Mar 31, 2004 | 09:59 PM
Mister 2's Avatar
The PDE uses the stock donut gasket and fits fine with the Borla.
Old Mar 31, 2004 | 10:44 PM
psychobooe's Avatar
The new Cobb downpipe also fits the stock/Borla flange.
I actually have the same situation. However, I've already purchased the Helix downpipe. I'm going to have to have a muffler shop weld a flat flange to the end of my Borla cat-back.
Old Apr 1, 2004 | 04:48 AM
TroyBoy24's Avatar
thanks guyz, yea im prett sure im gonnA go wit a high-flow cat because i do not want to be running catless, just not good. so if n e one has anymore infor, let me know
Old Apr 1, 2004 | 09:49 AM
PGM's Avatar
PGM
Car Info: 2K2 PSM WRX WGN
Hi. I'm currently running Borla Hush with Helix DP. I got the Borla hush since I couldn't bear the sound of my old Vishnu catless sig. series exhaust. I have a wagon so I think that makes it worse.
Anyway, I found out the Hush isn't so hush when running catless (Helix DP has no cats), although it is better than my old Vishnu setup. I'm now planning on getting the catted DP and 3rd cat eliminator from Daddy's SCP (http://www.daddysscp.com). The 3rd cat eliminator is basically a fake cat, which I'm hoping will pass my smog visual later. It actually uses a stock-like donut gasket, so it should fit well with the hush. I don't like having the hush mate with Helix (my current setup) since there's no flex joint to relieve the stress. Not to mention if you want a true 3in turbo back, you need to fabricate your own slip joint.
Just my 2c.
-PGM
jakeg
Jul 24, 2009 06:25 PM
whtSTI04
Apr 18, 2008 11:21 PM
06scooby
Oct 6, 2006 10:47 AM
Crisisback
Jul 20, 2004 08:25 PM
jroh_spice
May 7, 2004 12:53 PM
