Down Pipe Bolt Woes
Old Apr 15, 2003 | 08:22 AM
krillz's Avatar
Car Info: black o2 sedan
i broke two bolts tooo.... so i went out and got the right nuts to fit on the bolts that were still sticking out of the housing and used em, as far as size im not sure, bring one to autozone or wherever and match em up
ive had no leaks yet, but i am getting it fixed with the right bolts
Old Apr 15, 2003 | 03:11 PM
bone324's Avatar
Car Info: '02 WRX WRB
I'm not sure of the exact size, but I know that the rest of the stock exhaust has at least one or two more of the exact same nuts and bolts holding it on. If you're just planning on trashing your stock pipe you could salvage the nuts & bolts. I had a similar problem with a stripped nut and just replaced it with one from the stock exhaust. Good luck.
Old Apr 15, 2003 | 08:08 PM
ScoobyBoy's Avatar
at least you stripped the stud only. my buddy stripped the thread on the turbo when i was installing the uppipe. i brought it to the dealer to fix, nope cant work. only way is for them to make new threads or replace the turbo. so im running on 4 studs instead of 5. so far im not leaking.
well good luck with that.
Old Apr 16, 2003 | 04:00 AM
krillz's Avatar
what happened with me, is the top of the bolt just spun right off the bolt, bgreaking and leaving the peg in the turbo housing
so far im fine though
im sure someone will chime in and tell me im a jackassfor running like this
Old Jun 27, 2005 | 11:12 PM
mrhu's Avatar
after 4 hours..i too have similar woes =(
The nut at this point is completely stripped and refuses to budge. Is there any other option besides cutting the nut off?
Old Jun 27, 2005 | 11:35 PM
abbfanuc's Avatar
Car Info: 05 wrx blue
they have special tools called a nut extractor. kinda looks like a socket for a 3/8" drive ratchet. pretty sure you can get them at home depot, ace hardware. maybe autozone and pep boys.
Old Jun 28, 2005 | 07:53 PM
bpang1's Avatar
Car Info: '04 WRX Wagon
Guys...perhaps a Torque Wrench is in order? You big beefcake bolt breakers!
nation
Mar 18, 2011 02:13 PM
flatline
Dec 19, 2009 09:56 PM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
Dinko81
Dec 30, 2003 04:52 PM
