Diff Guard Clearance / Cat-back Question?
Old Mar 15, 2004 | 01:43 PM
stevedood's Avatar
Car Info: _
I had some trouble getting the Borla Hush cat-back system to clear the bolt heads on the rear differential guard. I managed to kinda get it to work but the tips are mis-aligned relative to the cutout in the rear bumper.
Does anybody have a trick to get around these bolt heads/diff guard (besides removing it completely) and keep the pipe from touching them?
Thanks,
Steve
Old Mar 15, 2004 | 04:35 PM
blue blurr's Avatar
i dont know but you could cut away at the diff gaurd, like cut a hole or something where the cat-back goes. there is probally an easier where but i dont know it.
Old Mar 15, 2004 | 04:57 PM
stevedood's Avatar
Car Info: _
Here is a photo showing the diff guard.
The last bolt head (after the clamp, out-of-focus) is barely touching the side of the pipe.
I had to tweak the muffler to get it to barely clear.
Should I remove the bolts?
Grind the heads?
Try a different fastener ?
Remove the diff guard (last option)?
Old Mar 15, 2004 | 05:06 PM
wrx10404's Avatar
Car Info: 04' wrx
Try Almost flat Allen head bolts. You may have to grind em. The problem with grinding those bolts is that you may tear em up trying to get them on and off.
Old Mar 15, 2004 | 05:14 PM
stevedood's Avatar
Car Info: _
You mean countersunk, right?
Does anybody know if those are M10 size?
Old Mar 15, 2004 | 05:16 PM
wrx10404's Avatar
Car Info: 04' wrx
yep. Don't know the size though.
Old Mar 15, 2004 | 08:03 PM
gbmotorsports's Avatar
Former Sponsor
Car Info: I got a couple :)
bring it by the shop or try moving the piping forward to get more clearance. They slide front to back and even rotate. Longer hangers are also available at the shop..
Eitherway call before comming over so we can assure that we can work on it
gino
Old Mar 16, 2004 | 09:02 AM
stevedood's Avatar
Car Info: _
Yo Gino,
Thanks for the advice. I spent a couple hours messing with both pipes to try to keep it away from the bolt heads but didn't have much luck.
I'm going to order some Countersunk stainless hardware from McMaster and give that a try.
Do you know the size/length of the fasteners?
Thanks,
Steve
edzwrx
Subaru OEM Parts For Sale
Jul 26, 2005 08:13 PM
stevedood
Apr 1, 2004 05:36 PM
gbmotorsports
Aug 25, 2003 04:40 PM
salaki
Apr 7, 2003 11:06 PM
ShotgunTC88
Feb 3, 2003 12:43 AM
