Data logging Programs
Old Mar 30, 2003 | 02:01 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Depends what you want to do. There are several dataloggers that read generic OBDII data, which is fine for some simple diagnostic work but rather limited for anything else such as serious tuning. If you want to be able to see and log all of the info being processed by the ECU (all sensor inputs and signal outputs) you need a Delta Dash, which you can check out at www.ecutek.com
The DD is the only unit, other than the Subaru Select Monitor used by the dealer, that can read the full set of ECU parameters.
Krang
Jan 29, 2009 02:19 PM
4080wrx
Nov 29, 2007 07:13 PM
VRT MBasile
Mar 16, 2007 11:29 AM
MO REX
Sep 21, 2006 09:09 PM
MinesPunk
Sep 1, 2004 03:17 PM
