Damaged VF30???
Re: Damaged VF30???
Originally posted by evilwrx
Does this turbo look ok? It is brand new, but looks a little damaged. Any thoughts.
2. The bolt on the back of the turbine is also normal since that's one of the ways IHI balances its turbochargers.
3. If the fin on the turbine is painted a little (white or something) then that is the mark used to balance the turbo and is also totally normal.
Car Info: 2002 WRB Subaru WRX / Vishnu Stage 2
Re: Re: Damaged VF30???
Originally posted by Turboxs_Nathan
1. The weld spot on the waste gate flapper is normal
Exactly as stated above
No worries there, my VF30 appeared the same way(besides the bend in the line, not much to worry about there either though)
L8R,
King
