Cusco heatshield?
Old Aug 15, 2004 | 02:19 PM
yamatodamashii's Avatar
Car Info: s2
Cusco heatshield?
anybody here using the cusco heatshield, if so was it a pain to put in ??
Old Aug 15, 2004 | 04:07 PM
bassplayrr's Avatar
I'm using it. It is SUPER easy to put in. It uses one of the intercooler bracket bolts for mounting, so just take that bolt out, slide the heatshield in under the intercooler and replace the bolt. Piece of cake.
-Chris
Old Aug 16, 2004 | 02:45 AM
rustokman's Avatar
Car Info: Black 03 WRX
Wouldn't you want to remove the old heat sheild? That is a bit more complicated as you would want to remove the intercooler for that. Still pretty easy though, shouldn't take more than 15 minutes.
Old Aug 16, 2004 | 10:34 AM
bassplayrr's Avatar
Yeah... my bad. I was assuming this was going on an aftermarket DP. But yeah, if this is going on your stock DP you will need to remove your stock heatshiled and its 8,000 screws.
-Chris
Old Aug 16, 2004 | 04:24 PM
Car Info: s2
ya i got a helix dp, jus too lazy to cut the stocker...tha heatshield went on in all of 5 min....thanx guys
Old Aug 16, 2004 | 04:45 PM
SooKy's Avatar
Is it important to have the dp heatshield? Cause I just left mine off when installing my stromung dp and theres no bolts that will allow for it to go back on like the stock dp.
Old Aug 16, 2004 | 06:13 PM
AWD 20T's Avatar
Car Info: 2009 G Ride
It isn't that important to have the stock heatshield in place, but it will help keep temps down under the hood.
Old Aug 16, 2004 | 07:56 PM
bassplayrr's Avatar
Yeah, you don't NEED one, but it is a good idea. Considering how close the top of that DP is to the IC I think you're better safe than sorry.
-Chris
Old Aug 16, 2004 | 08:59 PM
SsTiNgEr77's Avatar
Car Info: 2002
with a tmic, it is def usefull to have a heatshield, cuz once you stop that heat will just be toasting the bottom of the intercooler
Old Aug 17, 2004 | 06:20 PM
SooKy's Avatar
The cusco heatsheild is for the dp? I thought it was for turbo =/
Old Aug 17, 2004 | 06:50 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Will this heat shield work on a turbo XS dp and if so where can I purchase one?
Forget it, I found one at Z1 and there is a pic of it on a turbo with a TXS DP.
Old Aug 17, 2004 | 07:37 PM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
Speedmonkee Performance heat shield or chimney are a great product too.
Old Aug 17, 2004 | 08:21 PM
bassplayrr's Avatar
Kinda one in the same. The heatshield covers the turbo as well as the bell mouth area of the DP.
-Chris
Old Aug 27, 2004 | 12:35 AM
kettsupp's Avatar
Talking
my stocker heat shield deffinatly won't fit over my 4'' downpipe
Old Aug 27, 2004 | 10:31 AM
AWD 20T's Avatar
My stock heatshield fits over the Helix and Vishnu DPs... I want a cookie.
Labmonkey
Hawaii Classifieds
Mar 28, 2012 02:52 AM
microwave
Jul 8, 2011 01:27 PM
jondl
Mar 10, 2009 02:54 PM
STINGR
Oct 28, 2005 06:53 PM
AWD 20T
Wanted
Oct 2, 2004 05:10 PM
