Cobb California Gas Map Road Dyno Comparison
Old Aug 19, 2004 | 08:00 PM
Slack's Avatar
Car Info: '02
Well I just went and flashed in the Stage 2 California Map that Cobb just released. Results were a bit disappointing but pretty much what I had expected, as far as numbers go 7 peak HP less, as you can see they are pretty much the same until around 5000 RPM then the Stage 2 HWG map outperforms the California map. Something to note, I had about the equivalent of 93 octane when the California map was run(straight 76 91 Octane for the other), I dont see how that could do anything but inflate how well the CA map performs, so it will be interesting to see how well the CA map performs on regular CA gas.
The following is Road Dyno graph, it's pretty consistent, the runs were taken from the same starting point, roughly the same weather conditions. The numbers aren't worth anything compared to another car on a dyno, but they are very much comparable between different runs with the same car. Absolute numbers are meaningless, you should only focus on the change from previous runs. This is on very heavy smoothing, on an auto tranny the dyno must be done in 2nd gear, but 3rd would be more desirable, the results are still very consistent, albeit a bit rough.
RED is Stage 2 HWG Map
BLUE is Stage 2 CA Map
Old Aug 19, 2004 | 09:01 PM
RussB's Avatar
Car Info: $200,000 sports car
bleh. hey, how hard is it to road dyno a car? I'd be interested to see how my car does on the road dyno.
Old Aug 19, 2004 | 09:34 PM
Slack's Avatar
Car Info: '02
Find a flat road, put it in 2nd and mash the gas. As long as you have a laptop and delta dash, which I'm sure Scott can help you with.
Old Aug 20, 2004 | 07:38 AM
Slack's Avatar
Car Info: '02
Just got a chance to compare logs from before/after.
Other things of note:
Signs of detonation are gone from my Delta Dash logs, no more abrupt dips in timing, so that right there makes the map worth it for me.
Delta Dash reported IDC same gear same RPM before/after 92% vs. 97.5% so definitely running richer.
Ignition Timing is pretty much the same a bit more timing on the CA map, and the CA map the advance multiplier is at 15 opposed to 16 before.
Boost is the same as the HWG map, surprisingly Waste Gate Duty Cycle is higher with the CA map
Old Aug 20, 2004 | 09:02 AM
j*bishop's Avatar
Car Info: ass, grass or cash. no one rides for free
coo stuff guys. maps look promisin
Old Aug 23, 2004 | 04:18 PM
Jimbo's Avatar
Slack - What year is your WRX? I assume you have an '04?
Jimbo
Old Aug 23, 2004 | 07:58 PM
Slack's Avatar
Car Info: '02
Jimbo
02
Old Aug 23, 2004 | 11:55 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
its about damn time they make a real cali map! Sounds promissing that its richer as cobb's stuff seemed to be on the lean side especially the problematic cars.
-- Ed
Old Aug 26, 2004 | 09:46 PM
RussB's Avatar
slack, how do you get DD to store the custom gear ratio's for the automatic?
Old Aug 27, 2004 | 07:24 AM
Slack's Avatar
Car Info: '02
You can't, what I do is just open up a previous road dyno file, and it will have the ratios there.
Old Aug 27, 2004 | 07:58 AM
oct1285's Avatar
Car Info: iono nemore
sorry for the newb question but wat is the stage2 california map for? fuel economy?
Old Aug 27, 2004 | 09:57 AM
RussB's Avatar
ahh, excellent. now do you get the car rolling in 1 and shift to 2 right before you jump on it? or start in 2?
Old Aug 27, 2004 | 12:21 PM
RussB's Avatar
nm. figured it out. hit 188 whp and 198 lb*ft in second.
verc
Feb 8, 2007 07:29 PM
puckboy
Jun 15, 2006 04:52 PM
carletto
Jul 23, 2005 03:20 PM
kidatari
Sep 9, 2004 12:22 AM
CupertinoSteve
Dec 13, 2002 09:01 AM
