compressor surge? W/G chatter? wtf?!
Old Jun 29, 2009 | 11:15 PM
JERMz_707's Avatar
Car Info: ...02 MBP WRX
so i just bought a bug eye from a used dealership...all was well with the world...it came with an sti catback, a perrin inlet hose and intake hose, but its mated to my stock intake box...blahblahblah...so heres my question...when i get on the throttle, it makes a whoooooshing sound(which i thought was vacuum + more airflow because of the inlet pipe) and then boosts clean no shakes, no jerks just clean boost...and then when i get off of the throttle, i can hear a whispering *shashashashasha*(wtf?) is that normal? one of my boys told me that it was surge...which means im killing my turbo due to the fact that instead of the excess air thats supposed to get recirculated BOV-->inlet-->turbo...isnt working right....instead, its just dumping the air back AGAINST the turbo which can lead to bent fans,shaft damage, etc.etc..has anyone else experienced this shi*t? ive done some research but it seems like everything i read about it on other forums goes on extreme tangents...any insight would help...thanks...
-jermz
Old Jun 29, 2009 | 11:44 PM
JERMz_707's Avatar
surge? wastegate chatter?
**i posted this in newb faqs too**
-jermz
Old Jun 30, 2009 | 06:28 AM
strider327's Avatar
Car Info: 2005 WRX
Does it have a blow off valve or a boost leak?
Old Jun 30, 2009 | 08:12 AM
DemonPossessed's Avatar
Car Info: 05 wrx
it sounds like compressor surge to me..... not good. if it has an aftermarket bpv/bov you may want to locate a stock one and swap it out. in the mean time check if the aftermarket one to see if there is anyway to adjust it.
Old Jun 30, 2009 | 08:39 AM
-jermz
yes my car compressor surges at high boost
can you post a video of it?
what kind of BOV do you have?
IT COULD BE BOV FLUTTERING!!!!
Old Jun 30, 2009 | 08:40 AM
and i merged your two threads
welcome aboard
Old Jun 30, 2009 | 01:23 PM
JERMz_707's Avatar
it has a stock bov...BOV fluttering?** what is that? same thing? ahhhh! boost leak? how would i know, theres no stock boost gauge...eyo sigma pi, whats bov fluttering? is that a bad thing?
Old Jun 30, 2009 | 01:36 PM
no it opens and closes rapidly it makes a fluttering sound
can you post up a video of it?
Old Jun 30, 2009 | 01:51 PM
JERMz_707's Avatar
ok...problem solved. now its just a clean short pshhhhh* thanks guys! there was some kind of pressure regulator on the hose that runs from the manifold to the stock BOV, that was restricting air...took that sh*t off, and now my car is running HEALTHY! thanks again. peace.
-jermz
Old Jun 30, 2009 | 02:48 PM
hmmm dont know what that is
Old Jun 30, 2009 | 05:56 PM
JERMz_707's Avatar
i called up EQ and they said it couldve been something that was linked to a manual boos controller? i dunno...whatever it was, it was killin my shi*t. sall good tho...
ojichan sti
Sep 9, 2007 10:08 PM
Blu200sx
May 11, 2006 02:55 PM
gpatmac
Feb 21, 2004 02:56 AM
RshaoKh
Apr 29, 2003 11:28 PM
RshaoKh
Feb 16, 2003 10:40 AM
