cold air mistakes
Old Mar 21, 2003 | 06:14 AM
Wingless Wonder's Avatar
Originally posted by scbywgn
I do know that cai's help some cars a tremendous amount and other cars not very much.I have an AEM cai and haven't noticed any problems. It's awfully loud though.
I see big horsepower claims by many CAI makers, but haven't seen any third-party dyno testing to back up these claims. I have seen a car on Vishnu Performance's AWD dyno with a messed up air/fuel ratio curve from a simple aftermarket intake mod (not CAI). Shiv claims this was typical of most every CAI unit he's come across - messed up fuel curve that can be compensated for with about 45 minutes to an hour's worth of dyno tuning for no appreciable gain over stock.
I choose to believe what was written in the mentioned thread because otherwise Vishnu would've put a CAI on the market by now.
Old Mar 21, 2003 | 08:38 PM
Originally posted by navwrx
But, I still can't bear to part with my shiny cai unless I can see proof that it's harming my engine. Another concern was with running 16 pounds of boost through my mbc will this further complicate things since stock mafs don't read correctly with cai's? And if anyone knows where that thread from Shiv is could you please point it out here for anyone who hasnt bought thier aftermarket intake yet?
I put a thread link in my previous post, but here are some search results.
I can't prove that your CAI is causing problems. I don't believe it's harming your engine, though. You can read those threads for yourself and make a determination from there. It isn't worth paying for the dyno time just to see your air/fuel curve compared to the stock airbox, unless you were already planning on a custom tune.
Old Mar 23, 2003 | 11:20 PM
CirrusWRX's Avatar
Just from what I read, I don't think a lot of people would condone that approach, yet so many people do it, so I guess it's a moot point. The people smarter than me say it's detonation that kills our engines. (Makes sense, no?) So in combination of some things, you take a CAI which is quite possibly leaning out your engine. Running lean can increase your EGTs - do you have an EGT gauge? While it's not "a=b=c" typically, higher egt's and leaner mixture go hand in hand and can dramtically INCREASE your likelyhood of detonation. And what abuot the MBC turned up to 16? Running more boost than the computer knows what to do with (without engine tuning) causes the turbo to begin to work outside it's efficiency range. Hotter air gets pumped into the cylinder, hotter "dry" (too lean) air spells even more trouble for detonation. Just sounds like a bad plan in my book if you're running this setup with
1. No gauges to monitor EGT or A/F
2. No knocklink to detect detonation
But, like I said, your setup HAS to be the most common "general modding" setup I have seen out there, and I haven't seen much. So I guess, on one hand, everybody else is doing it, but on the other hand, the people "in the know" don't condone it.
Old Mar 25, 2003 | 10:07 PM
CirrusWRX's Avatar
bling bling?
(I think you are making a wise decision, but don't let me influence you any further!!!)
Old Mar 25, 2003 | 11:11 PM
oldmansan's Avatar
Personally,
I'd be more worried about your MBC set at 16 psi than your CAI.
San
c279a
Rife Plazapalooza
51
Mar 14, 2007 09:22 AM
thunder_sti
Aug 3, 2006 01:55 AM
Salty
Sep 20, 2004 06:05 AM
