Cobb or Vishnu
Old Feb 11, 2004 | 05:01 PM
DOHCammin's Avatar
Car Info: 05 CGM FXT STi
thanks for the info shiv. I was hoping for over 200whp with the flash and those numbers sound very impressive.
Old Feb 13, 2004 | 05:40 PM
WRXncrew's Avatar
Car Info: http://goo.gl/XpkO0b & '99 SF 'S'
Originally posted by Vishnu
Hi there,
[snip]... As for porting and polishing the factory turbo, it shouldn't make much of a difference if done well. If done improperly (which is more common from what I've seen), performance will be compromised for good. It is my opinion that you leave the factory turbo untouched
Could you please explain more about what you've seen regarding the P&P? There are people who get their turbos reworked, so that they can eliminate boost creep. Are you saying this was not done correctly, or that it doesn't make any difference, or that it made things worse?
Old Feb 14, 2004 | 06:36 PM
Vishnu's Avatar
Car Info: 996 Turbo,Gallardo,BMW 335,125cc shifter kart,etc
All of the above. About the only thing I would ever consider doing to a turbo is extrude honing the exhaust housing. Nothing else. No porting, polishing, etc,. No mods to the compressor side. Most of the turbos that I've tested with ported wastegate housings usually leak (don't seal properly). This is caused by human error which, unfortunately, is pretty common.
Just my experience though...
Shiv
________
Circle l engine
brucelee
Jul 26, 2006 12:11 AM
blk rex wagon
Feb 2, 2005 04:16 PM
titsataki
May 11, 2004 01:25 PM
mysube97
Jan 14, 2004 05:52 PM
David@VISHNU
Dec 10, 2002 07:40 PM
