Cobb tuning dp
Old Mar 11, 2004 | 08:57 PM
Ben's Avatar
Ben
Car Info: Stock....so far
Cobb tuning dp
all right guys,
i've finally decided to go to stage 2. Due to budget constraints, here is what i am thinking:
1.) cobb tuning dp, catted for emmisions.
2.) Helix flex uppipe
3.) Stock catback, until more $.
4.) AccessPort.
5.) New gaskets.
See anything missing ?
Just running it by you guys. Tell me what you think. Thanks
Old Mar 11, 2004 | 09:21 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Im not positive but I think you need a full turbo back exhaust. Im pretty sure Cobbs website tells you what mods you need to go stage 2.
Old Mar 11, 2004 | 10:50 PM
Chrisnonstop's Avatar
Car Info: 02 Silver WRX sedan. Eibach springs, Blitz NUR cat back, Rota 17" Attacks, Cobb AccessPort/DP
D/P is all
For the Cobb Stage 2, the minimum requirements are:
Stage 2 reflash
Down-Pipe
Of course it would be a good idea to get rid of that stock muffler. Up-pipe is supposed to be a good mod too.
Old Mar 12, 2004 | 08:04 AM
Ben's Avatar
Ben
Thanks guys, ordering today
Old Mar 12, 2004 | 08:25 AM
Rock Strongo's Avatar
Car Info: 2004 WRX Sedan
Originally posted by Ben
all right guys,
4.) AccessPort.
5.) New gaskets.
Let me know how it runs.. I have been researching the same path. I do not think you will have any problems. There are some threads on wrxforum.com that has some info on going stage2 with only a downpipe.
Good luck!
Old Mar 12, 2004 | 10:19 AM
TQuintin's Avatar
Car Info: 2007 STI
Talking
Cool... keep us in the loop with the results!
I'm thinking about ordering the Cobb DP and keeping the stock cat back section of the exhaust... probably will get a Stromung 3'' once I get the money.
AccessPort is on order... Can't wait until Mid-April to get it!!!
Old Mar 12, 2004 | 11:01 AM
SsTiNgEr77's Avatar
Car Info: 2002
cobb downpipe is good product, but imo overpriced...
u can get used bellmouth d/p's for ~ 225 ish and they will give u the same power as that cobb, but if your sold on it go for it...
Old Mar 12, 2004 | 06:43 PM
brentlz's Avatar
Car Info: 2002 Impreza WRX
Hey Ben,
I'd definitely like to hear your impressions of your setup once it is running. I'm leaning towards something very similar:
1) Cobb downpipe with cat.
2) APS flex uppipe.
3) Stock catback.
4) Prodrive (WR Sport) axle-back.
5) AccessPort.
Brent.
Old Mar 14, 2004 | 11:31 AM
Ben's Avatar
Ben
thanks for the input guys,
i looked at the aps uppipe too.
it was the price of the helix that got me. i got the uppipe, full gasket set, and it was shipped free for $200. not bad i'd say. can't wait till it comes. cobbs on backorder for about 4-6 weeks.
cheers
ben
Old Mar 14, 2004 | 11:39 AM
daybreak's Avatar
Car Info: MBP is the blackest of blacks. HOLLA BLACK!
buy the HELIX DP instead. Dirt cheap and excellent build quality.
About COBB Stage 2 w/just an UP/DP - My buddy has the same settup, COBB advised him to get the Stage 2. He's boosting a little over 15.0 PSI (the ECU is still learning however).
COBB Stage 2s are suppose to be boosting at 15.8 at maximum efficiency
Old Mar 14, 2004 | 04:50 PM
daybreak's Avatar
Mastros,
A quick breakdown:
UPIPE - pipe connecting exhaust headers to turbo. The stock uppipe has a catylitic converter in it (therefore impeding airflow). Aftermarket uppipes eliminate the catyltic converter, which improves exhaust flow to the turbo (reduces turbo lag)
NOTE: You CAN pass smog(even in CA) w/out the UPpipe CAT. You probably won't pass smog w/out the DOWNpipe/MIDpipe cats.
DOWNPIPE Exhaust piece immediately after the turbo. The stock downpipe(and midpipe) have 1 catylitic converter each. Aftermarket downpipes eliminate either 1 or both CATs (depending on the aftermarket downpipe) Also, note that the stock DownPipe blocks off the waste-gate exhaust of the turbo. Aftermarket downpipes (excluding the HKS downpipe) are either Bellmouth or DivorcedWastegate designed (both are designed to expell wastegate exhaust). Downpipes are usually 3" as opposed to the stock pieces which are 2.5" i believe.
TURBOBACK EXHAUST all the exhaust components from the turbo on back (Downpipe + a catback would constitute as a full turbo-back.
COBB tuning AccessECU/Accessport
www.cobbtuning.com (sorry, i'm lazy)
Old Mar 14, 2004 | 08:41 PM
TQuintin's Avatar
Car Info: 2007 STI
As far as the Helix DP goes... I'd love to get it. Good quality, inexpensive, and good power gains. But it doesn't have a cat.
I'm not sure if I'd want to go catless. I'd feel a little guilty about the added pollution, and I don't think my girlfriend would appreciate the smell very much.
Old Mar 14, 2004 | 08:47 PM
daybreak's Avatar
Originally posted by mastros2
I was referring the power output.
damnit man. then say so! it took me a lonnnng time to type that. not to mention 7 revisions.
you were a bit vague!
power output for a full catless TBE is 25 HP at the wheels + 10 more HP for the uppipe (supposedly)
