Check engine light on and off plz help!!
Old Mar 11, 2004 | 04:57 PM
minisiu's Avatar
My wrx check engine light on and off, the first time the light on, i took it to dealer they said it was bad wire of purge valve sensor.
after few days, check engine light on again
and i took it to dealer agains this time they replace the purge sensor. But after a week, check engine on agains!!!
Now, f-u-c-k up! plz help
I think it happened after i installed hks tt!!
Mod i have on my wrx
Intake exhuast hks bov and hks type 1 tt
Poissible reasoni think)
Bad wire
ECU
Bad sensor (bad luck are bad)
speed sensor?? (i don't know)
bad vaccum????
Well i check the connector of the sensor it read 13.6 volt.
Old Mar 12, 2004 | 02:41 AM
well i doubt the TT had much to do with it if you disconnected the battery and had the harness, i mean its just plug and play
Old Mar 12, 2004 | 06:29 AM
minisiu's Avatar
My is hks type 1 which has rpm and speed and i did hook it to ecu speed sensor and rpm sensor. i am, going to check any lose wire tonight i hope i get luck
Old Mar 12, 2004 | 11:15 AM
My ecu radomly came on it was a misfire 301
Racerkid
May 29, 2012 06:16 PM
Katalyst
May 19, 2009 05:36 AM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
toekneepark
Mar 28, 2003 09:33 PM
