check engine light
Old Apr 13, 2004 | 06:00 AM
Big_DeWeY's Avatar
Car Info: Silver 02 WRX
go to www.gruppe-s.com and get the CEL fix for the downpipe. the light is due to your downpipe's o2 sensor freaking out. the CEL fix tricks it into thinking it's OK.
Old Apr 13, 2004 | 07:19 AM
esracer's Avatar
Car Info: 2002 Honda S2000
I think we need to make this thread a stickaroony, this question is a good question, but it is asked too many times.
Old Apr 13, 2004 | 08:46 AM
wrx10404's Avatar
Car Info: 04' wrx
Re: check engine light
Originally posted by kurban
since i install the downpipe and cat back exhause. my engine light is on. do you guys now why. how do i fix that.
Do a search on here for cel fix's. There are elctrical and mechanical fixes. I have the mechanical and it works great. No cutting or splicing
Old Apr 13, 2004 | 08:19 PM
wrx10404's Avatar
Car Info: 04' wrx
https://www.i-club.com/forums/showth...threadid=47592
Here. I also think if you pm WRXncrew he may get on made for you as well. or you can make it yourself.
Heres that link.
https://www.i-club.com/forums/showth...hlight=cel+fix
Good luck
Old Apr 17, 2004 | 08:03 AM
wrx10404's Avatar
Car Info: 04' wrx
Kurban, Any luck?
BTW: you will have to reset the ecu after you install any of the fix's. Do a search for that on here.
Old Apr 17, 2004 | 09:41 AM
liquid_sword's Avatar
Car Info: silver 03 rex
i have had the same prob first with the cat back and that was because my dumb a$$ did not reset the ecu right after good rule of thumb reset ecu after every mod. as far as cell fix for your o2 sensor the gruppe-s cell fix is the best IMO and cheepest electronic fix i have found. oh yes and to reset your ecu disconnect the negative batt. cable and pump the brakes a few times and bingo your ecu is reset.
Old Apr 17, 2004 | 09:48 AM
escaflowne's Avatar
Car Info: 2004 Black WRX wagon
i installed a catback exhaust and now my CEL is tripping out. Lol. thing goes on and off all the time... i just have to reset my ECU? is it seriously that easy to do?
wait. i thought our ECUs learn from the way we drive. sigh, that means a couple hard runs....
Old Apr 17, 2004 | 09:57 AM
Mulder's Avatar
Car Info: 02 WRX WRB
A catback alone should not cause a CEL. You should get the code read to see what it is so you can proceed accordingly.
Even if you don't do a reset, the ECU is constantly learning, so if it needs to adapt to any mods it will do so on its own eventually.
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
