check engine light...
Old May 29, 2005 | 11:06 PM
4aghumper's Avatar
Car Info: 1986 Toyota Mr2, 2002 Subaru WRX wagon
ok what gives? my car keeps throwing codes for misfires on different cylinders. i've tried running a couple gallons of 100 mixed with our crap 91 here in cali but still codes. i have tried to contact vishnu but i don't really have much time right now to get it on the dyno. so any suggestions would be great...
Old May 29, 2005 | 11:13 PM
duo's Avatar
duo
Car Info: WRB WRX 2004
it could be your plugs...just a thought...how many miles do you have on your car? that would help the gurus i bet( and mods too)
Old Jun 1, 2005 | 04:58 PM
4aghumper's Avatar
the car is near 60k i have vishnu stage1 incl. pully and reflash tuning. and the cell fix has been performed. i'll have to check the plugs. any suggestions on what to use if i do replace them (temp-wise) thanks again for any help gurus...
Old Jun 16, 2005 | 10:18 AM
STi-owns-evo's Avatar
Car Info: '02 PSM WRX
misfire means that the gas is not igniting. Therefore, why put higher octane which is harder to ignite? With 60k, I'd say get a new set of plugs.
Old Jun 16, 2005 | 10:25 AM
4aghumper's Avatar
yeah i figured that out... thanks though... do you have a plug you can recommend? should i go with a colder plug that stock since i have the tuning or should i switch to irridium... i'm not really that sure about what to use, and i don't have a dealership near by that i feel i can trust. thanks to anyone who can help me out...
Old Jun 16, 2005 | 10:27 AM
norcalridin's Avatar
Car Info: 2002 WRB WRX
wouldnt higher octane be easier to ignite, its more flamable, so that means it needs less spark to ignite it... just a thought...
Old Jun 17, 2005 | 09:54 AM
WRX_2NR's Avatar
Car Info: 04 WRX
Are you running Vishnu Xede?
Misfire problems in 04-05 models, need a reflash to correct this problem
Old Jun 17, 2005 | 06:29 PM
slvrsubywgn's Avatar
Originally Posted by Wingless Wonder
That's the reason owners of more mundane cars such as Saturns and Suzuki compact cars are probably wasting money by switching from the recommended 87 octane regular unleaded to 91 or higher octane - it has no benefit to the performance or gas mileage figures. The octane itself doesn't add the power - it just resists detonation better so the car can be tuned with a more aggressive ignition advance (or boost in turbo cars).
Alittle info on higher octane. Hope you don't mind me quoting you, WW. I just thought this to be a good insight on the subject. It helped me to understand, anyways!
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
