CEL fix question....
Old Sep 21, 2004 | 10:14 AM
RussB's Avatar
Car Info: $200,000 sports car
you only need a cel fix for the rear o2 sensor. the front o2 sensor is installed in the exhaust manifold before any cats. you may need a cel fix for the egt probe though.
as for the rear o2 sensor fix, there's electronic and there's mechanical. i'm running the mechanical fix and it works great. basically, get a 2 pack of 18mm spark plug non foulers and drill out to 1/2 inches. install the o2 sensor in that one. screw that into the non fouler that you didn't modify. screw the whole thing into the sensor bung on your downpipe and you're good to go. this gives you enough difference in readings between the two sensors to not trigger a cel.
Old Sep 21, 2004 | 12:41 PM
New2MeSuby's Avatar
Car Info: 2007 Mazdaspeed 3, Black, 6spd
the egt fix is a 22k ohm 1/2 watt resistor across the two wires of the cat over temp sensor from the up pipe. if you leave the sensor out it wil throw a check eng light
Old Sep 21, 2004 | 01:08 PM
RussB's Avatar
the need for an egt fix depends on the up-pipe. i'm running an s-squared flex up-pipe with no fixes. i've never had a cel.
Old Sep 21, 2004 | 01:10 PM
Mulder's Avatar
Car Info: 02 WRX WRB
It's actually 2.2K, not 22K.
Old Sep 21, 2004 | 01:48 PM
NWWagon's Avatar
Car Info: 03 Wagon
IF you so desired Helix can get you one, they should have included it with their Downpipe.
Old Sep 21, 2004 | 07:32 PM
wonton2049's Avatar
Car Info: 2005 STI
mechanical fix:
this in my opinion is preferred. no wire splicing so less confusion.
if you need a detailed explanation, go to
www.cardomain.com/id/nycxwonton
i think i have instructions on page 2 or 3. no pics though. sorry. very quick.
Old Sep 22, 2004 | 12:06 AM
RoadSpike's Avatar
Also the egt shouldn't be an issue unless your running higher boost in which egt temps could cuase sensor meltdown. The helix should plug right in and cuase no cels. If you do not want to worry about it simply use the for mentioned resister fix.
beardog
Jan 17, 2005 07:42 PM
esracer
Mar 18, 2004 06:22 AM
esracer
Mar 16, 2004 11:56 AM
MHC
Sep 7, 2003 06:56 PM
