Cel fix for DP on ebay
Old Mar 30, 2005 | 10:52 AM
t3ch9's Avatar
Car Info: 2016 WRX
I saw this item on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...category=34203
has anyone tried it? Any feedback?
Old Mar 30, 2005 | 01:29 PM
RussB's Avatar
Car Info: $200,000 sports car
overpriced... the bolt and resistor are for the up-pipe egt fix if you removed the probe.
the other thing is actually 2 18mm spark plug non-foulers screwed together, it's like $3 in parts from pep boys. simply drill one of them out with a 1/2" drill bit to give clearance for the o2 sensor and screw that into the untouched one. and yes, this one works great. it places the sensor far enough out of the exhaust flow to register enough difference between the 2 o2 sensors and the ecu thinks everything it just fine.
Old Mar 30, 2005 | 02:15 PM
slvrsubywgn's Avatar
Dooo it! I actually just rigged my dp with this pepboys setup a few weeks ago and it seems to be working just dandy.
Old Mar 31, 2005 | 01:06 PM
t3ch9's Avatar
Car Info: 2016 WRX
ill give it a try, thanks!
Old Apr 2, 2005 | 10:41 AM
tsubaru02's Avatar
Car Info: 06 sti,03 wrx,06 leggy 2.5i
Thumbs up
i got those on ebay last month they work fine no cel for about 1000k so it works very good instruction and details the guy that is selling it is very nice to just get it you will be happy....
Old Apr 18, 2005 | 04:01 PM
t3ch9's Avatar
Car Info: 2016 WRX
Finally got a chance to do the CEL fix (2 spark plug non foulers) on a Perrin dp and there is barely enough clearance for the o2 sensor to fit. I had to play with the down pipe to get it to fit right. I could not put back the bolt that holds up the stock cat pipe. Is this normal? My car is lowered so I'm worried the pipe might hit a bump, if its big enough.
Old Apr 18, 2005 | 04:18 PM
Did your Perrin dp only delete one of the cats then? You still have your stock third cat?
Old Apr 20, 2005 | 10:20 AM
t3ch9's Avatar
Car Info: 2016 WRX
no, it deleted both. I also noticed a small leak with the stock midpipe. I guess the stock 3rd cat had a donut looking gasket. I guess I should have used 2 aftermaket gasket. that or get an aftermarket midpipe.
I_FLY_LOW
Feb 18, 2007 06:09 PM
esracer
Mar 16, 2004 11:56 AM
mrtrex
Vendor Group Buys/Specials
Dec 23, 2002 05:50 PM
gruppe-s
17
Dec 21, 2002 04:08 PM
jjunior887
Dec 15, 2002 02:20 PM
