CEL Code 1507
Old Oct 19, 2004 | 04:52 PM
Viking067's Avatar
Car Info: MY02, WRX Sti Prodrive
Checked the MAF?
Oil from filters may cause this to go bananas!
(P1507 Idle control system malfunction (fail-safe) )
Old Jan 10, 2005 | 02:45 PM
wrxtasy555's Avatar
Car Info: 2002 Wrb WRX sedan
I'm having the same problem. Any info will be greatly appreciated.
Todd
Old Jan 10, 2005 | 05:28 PM
New2MeSuby's Avatar
Car Info: 2007 Mazdaspeed 3, Black, 6spd
Clean out the carbon from the intake manifold. Buy a carbon busting product and clean behind the throttle plate, inside the idle control valve, pcv valve and any where else you can reach. I have also heard of possible ground issues causing this code. Check you engine grounds and wire harness grounds.
Old Jan 15, 2005 | 02:49 AM
Nate0125RS's Avatar
Car Info: '03 Silver WRX
I had different CEL, but same problem. It ended up being the Idle Control Valve on top of the throttle body. Expensive part ~ $300, but fixed the problem and CEL immediately. I got mine from Mastro Subaru (http://mastrowrx.com) Some people have had luck cleaning theirs, but that didn't work for me. Part 22650 in the attachment.
subaruferrucci
Apr 11, 2006 12:51 PM
plucky
Aug 30, 2004 10:44 AM
20WRX02
Dec 5, 2003 02:53 PM
lisa
Jan 17, 2003 05:31 PM
MeaCulpa
Dec 15, 2002 06:19 PM
