Cel
Old Nov 14, 2003 | 10:32 AM
fstbluewrx's Avatar
Car Info: 2010 LANCER GTS
Angry Cel
I finally got my car dyno tuned this week at Altered Atmosphere in MD.The rex made some good numbers.Could have done a little better even, but i have a boost leak that ill be fixing soon. The car drove home ok, no wierd noises or anything. No cels, until a couple days later when i went to give my friend a ride. We were driving down the road and i was going through the gears fine until i hit 3rd and the cel flashed a couple times when i got on it. I of course was like wtf and let off the gas, so i dont know if it would have kept on flashing or if the ecu was seeing something for a split second.But it doesnt do it all the time it only does it hear and there.If anybody has had this happen or might know what it is any help would be great! Thanks
Old Nov 15, 2003 | 03:51 PM
international B's Avatar
Chewwwwy
a flashing cel is showing misfire. the cose will remain in the ecu, if you check pending codes it will show up. if you are running an aftermaarket boost controler it may also be overboosting, of overloading the maf. use an obdII scanner, and you should be able to see what it is.
Old Nov 15, 2003 | 08:47 PM
fstbluewrx's Avatar
the wierd thing is that my brother hooked it up to a scanner at work and it didnt show a code. the cel hasent come on again since a few days ago (crossing fingers) so maybe its all good now
thanks for the info though!
Old Nov 15, 2003 | 10:46 PM
Uncle Scotty's Avatar
If you are using a UTEC, then the flashing CEL is knock.
As the weather gets colder, the denser air will cause boost to go up a bit, so you may want to turn the boost down a bit or run some toluene...
Old Nov 16, 2003 | 07:31 AM
fstbluewrx's Avatar
i was thinking that, but its just wierd that it only did it a couple of times
Old Nov 16, 2003 | 04:46 PM
The ECU may have needed a few WOT runs to re-learn a bit of its map, too....
Old Nov 18, 2003 | 02:44 PM
fstbluewrx's Avatar
Thumbs up
yeah i hope thats all it is :banana:
MaVz
Jun 16, 2004 09:41 PM
esracer
Mar 16, 2004 11:56 AM
NeVzWRX
Jun 23, 2003 11:38 AM
flanagan
Jan 2, 2003 10:05 PM
NORSE
Nov 25, 2002 11:12 AM
