Cat is out of the bag - Vishnu ECUTEK + XEDE
Old Jan 29, 2003 | 03:32 AM
Wingless Wonder's Avatar
Originally posted by ShotgunTC88
Can you switch back to "factory" stock E.C.U settings?
I believe you can if the factory map was stored in the XEDE. Reading CupertinoSteve's comments, I'm not sure how a re-flash will affect this if we try to restore the factory map. Being able to change maps back to stock is one of the reasons I'd spring for the XEDE.
Does the Xede REMAIN in the car after flashing the E.C.U?
XEDE remains in the car. It doesn't actually re-flash the ECU. It piggybacks the ECU, but it is much more sophisticated than the Unichip.
Is the Stage Sub 0 map the same map I would get if I sent in my E.C.U for Reflash?
Pretty much, except for the advantages that CupertinoSteve cited about having both an EcuTek re-flash and XEDE.
^ww^
Old Jan 29, 2003 | 07:10 PM
CupertinoSteve's Avatar
Razor,
I be going to tonights SJ meet and tomorrows MV meet. (I guess I don't have much of a life).
Steve
Old Jan 29, 2003 | 07:27 PM
It would be worth the extra dough JUST to have the ability to switch from Sub 0 to Stock,
In case the Emmisions folk get picky......<GG>
My sentiments, exactly. We wouldn't be cheating the system. It will generate numbers like the Low Emission Vehicle that it is. But, just for an hour.
If I can get a free re-test from the smog station, I might run it with the Stage 0 map, just to have the emission readings to compare to stock. Without a load on the engine, it might not be too bad.
^ww^
suby_dude
Jan 15, 2006 10:16 PM
DaWorstPlaya
Sep 27, 2004 07:35 AM
David@VISHNU
Dec 10, 2002 07:40 PM
